Tracking / Autocross / HPDE / Drifting What these cars were built for! |
#169 |
Drives: Many
I have everything from +35 to +42, and I usually run a 3-5mm spacer with everything (with so much camber it's all fine).
I couldn't tell a difference in amount of rubbing between any of them and it smokes a fender liner maybe once a year (~250ish runs) regardless lol. Last edited by e1_griego; 12-22-2023 at 10:02 PM. |
#170 | |
Drives: 2015 FR-S
Second of all whether you rub depends on your 1) ride height 2) alignment 3) springs and shocks 4) level of grip and 5) how bumpy the site is. If a good driver on an ideal setup is cornering hard and hits a bump mid corner, that's going to take a lot to not rub. Whereas if the site isn't bumpy, it'd be much less likely. Anyway I run +35mm also with a 5mm spacer in front, with 4.8 camber and 245 yoks. I usually don't rub but sometimes will rub a little where the fender liner goes over the brake line at high grip bumpy sites. The rear I don't have a spacer, and no rubbing no matter what. I'd just do 35mm on a gen1. |
The Following User Says Thank You to jcaserta For This Useful Post: | autoracer86 (11-29-2023) |
#171 |
Drives: 2017 BRZ PP, 2004 WRX
Thanks, I'm edging towards +35 now. I kinda don't love the whole stancey boi look, but I guess with ~4 degrees of camber up front, it won't look bad. I have 3mm spacers on the car right now with ARP studs, so if it needs a bit of 'tuning' to get mine to fit, I have some wiggle room.
I did just pick up some RCE SS-1's today for a bargain. 1500 miles. Can't wait to get this setup for STX-lite. After 4 years in DS, I've had enough. My other option is getting the +42 and using the 3mm spacers to get around a +39. Problem is, if some people are rubbing on +35... eh, +39 won't be enough.
#172 | |
Drives: 2020 Subaru BRZ Limited PP
Sent from my SM-S916U using Tapatalk |
#174 | |
Drives: 2017 BRZ series.yellow
Plus this: https://www.ftspeed.com/products/a00...-inboard-mount |
The Following User Says Thank You to Breezio For This Useful Post: | kraftyone (01-14-2024) |
#175 | |
-4.3 camber up front. -1.7 camber in rear. I have a +35mm set of wheels and a +40mm set of wheels. No spacers. The +35mm setup I had a very tiny but of rub on the uppermost mounting tab for the rear bumper, shaved a few mm's off and no more rub. The +40mm setup I get a pretty strong rub at full steering lock on the inside fender liner and 'frame'. No other rubbing and on our primary lot I've had the car airborne mid corner. |
#176 | |
Drives: 2015 FR-S
#177 |
Drives: '22 BRZ
Good to finally meet a bunch of y'all at Charlotte, even if I was breaking up the Twin party this weekend! Was planning on driving my car, but last minute change of plans while my shocks are off for a refresh. Lead to some confusion at reg where my wife and I somehow ended up registered in my BRZ in STX instead of her RX-8.
My fastest runs for comparison:
The Following User Says Thank You to DocWalt For This Useful Post: | RT-BRZ (04-23-2024) |
#178 |
Drives: 2016 Scion FRS
Do we know how much toe changes by raising (or lowering) the car by say half an inch?
#179 |
Drives: '13 FRS - STX
From 27” down to 24” at the rear fender arch each inch of ride height lowered netted me a 0.04” increase in toe in.
The Following User Says Thank You to strat61caster For This Useful Post: | steverife (04-28-2024) |
STX setup sharing thread (2022) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 204 | 06-15-2023 02:34 PM |
STX setup sharing thread (2021) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 366 | 12-07-2021 01:57 PM |
STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 01:40 PM |
STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 11:27 AM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
