Old 11-13-2023, 12:18 AM   #1
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Looks like oil starvation issue in the right handers solved
Just read the comments. Plain and simple, no need to spend ton of money on baffles, let alone accusumps.
Arthur-A is offline   Reply With Quote
Old 11-13-2023, 08:09 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Comment says 1 liter overfill. @900BRZ tried overfill (IIRC 1 quart, which is almost the same) and that didn't help much.
Before declaring the problem solved I would say we'd want to see a before and after comparison of oil pressure that shows the pressure drop without the overfill and doesn't have it anymore with the overfill.
It might be that in Laguna Seca conditions aren't right for the pressure drop people see on other tracks. Or something in the way he drives. Or his oil pressure gauge is different (as it barely shows any fluctuations not related to RPM which seems unreasonable).
He's also running SX2 tires (in 245/40R17) with fairly low camber (-2.3F/-1.5R) which might not generate enough lateral G's for the pressure drop to occur.
The Following 10 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Balefire (11-14-2023), Desertnate (11-15-2023), Dzmitry (11-14-2023), jflogerzi (12-21-2023), OkieSnuffBox (11-13-2023), RedReplicant (12-27-2023), RToyo86 (11-13-2023), timurrrr (11-21-2023), Ultramaroon (11-13-2023), Wally86 (11-17-2023)
Old 11-21-2023, 02:15 AM   #3
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
T3: 3rd gear, ~5000 rpm, flat
T4: 4th gear, ~5000 rpm, flat
T10: 4th gear, ~4600 rpm
That's very different from what Brian / @900BRZ used in his tests.
Additionally, 1:48.85 is a few seconds off the pace of what 900BRZ's "test driver" would do in the same car.
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
Ohio Enthusiast (11-21-2023)
Old 12-18-2023, 03:12 AM   #4
intake92
Drives: GR86
I am the driver in this video, as what Timurrr said, I mainly am using a higher gear, esp in T4 and T10 to mitigate the issue, along with the 1L overfill.
I am also not as quick as other 86 drivers, which also can contribute to a better oil pressure reading. This is good news to those who are more novice/intermediate level, and won't have to worry as much.
In short, no, the right hander issue is not solved, at all. However, you can mitigate issues with 1L overfill and staying a gear up.
intake92 is offline   Reply With Quote
The Following 8 Users Say Thank You to intake92 For This Useful Post:
Arthur-A (12-18-2023), Blighty (12-21-2023), DriveDriftDogfight86 (12-27-2023), Ohio Enthusiast (12-18-2023), OND (01-10-2024), Spankopotomous (01-19-2024), systemmotorsports (12-18-2023), timurrrr (01-19-2024)
Old 01-17-2024, 10:23 AM   #5
Compelica
Compelica's Avatar
Drives: 86 GT
Apparently @900BRZ already has a solution in hand based on his latest video?
DIY stuff at Compelica Works
Compelica is online now   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
OldBiker (01-19-2024)
Old 01-19-2024, 04:55 PM   #6
OldBiker
Drives: 2023 Gray BRZ
I can't wait!! Looks like @900BRZ has had quite an adventure... replaced an engine too. It is hard to get proper attention when our numbers are so low, but very happy they are working on it. And what have we heard from the two auto companies... crickets!
OldBiker is offline   Reply With Quote
Old 01-19-2024, 06:14 PM   #7
jflogerzi
jflogerzi's Avatar
looks to be an accusump setup. It adds complexity and failure points but pretty cheap insurance for those who regularly track their cars
2013 Series 10 FRS #553
Innovate MTX-A boost gauge issue (solved) go_a_way1 Electronics | Audio | NAV | Infotainment 10 10-06-2016 07:08 PM
HID issue (solved, defective bulb) DustinDHP Cosmetic Modification (Interior/Exterior/Lighting) 5 10-09-2015 01:49 AM
Enkei 17x8 RPF1 Gold with Hankook Ventus R-S3, Torque Steer?! issue solved enginrd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-08-2014 01:00 PM
Headers: Has the CEL "issue" been solved? boredom.is.me Engine, Exhaust, Transmission 9 10-20-2013 09:35 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 10:14 AM
