Custom User Title
Drives: Asphalt FR-S MT
Headers: Has the CEL "issue" been solved?
Without getting a tune, how would one go about getting rid of the check engine light after getting headers?
Kev And yes I did search.
Drives: Silver 2013 BRZ limited
well you didn't search enough lol
you use whats called an "02 spacer" or defouler, all it does is push the sensor out of the stream of the exhaust flow |
Drives: Series 10 FR-S
Defouler causes sensor reading irregularities making it reading lean and telling the car to add more fuel to compensate till it reads the amount it needs.
Drives: I own an FR-S. . . whatelse!
I know you need an 02 spacer(or a tune) to get rid of the CEL, but I was wondering if this will cause any problems in the long run?
| The Following User Says Thank You to IAmNotTheDriftKing For This Useful Post: | boredom.is.me (10-20-2013) |
Drives: 2013 FR-S whiteout
| The Following 2 Users Say Thank You to SloS14 For This Useful Post: | ATL BRZ (10-20-2013), Fast_Freddy (10-21-2013) |
Defouler aka spacer aka 90 degree bent fitting.
Drives: Scion FR-S A/T, Whiteout
Another thing you can try is relocating the secondary O2 sensor behind the cat in your front pipe. Weld a bung, extend the wires, profit. The primary O2 sensor needs to stay in its current position though.
This information was garnered from other posts here and is not my own experience, so take it with a grain of salt. This is my plan if I decide to go with a non-catted header, in addition to tuning the cat inefficiency code out. |
Tune is best. Welding an O2 bung behind the front pipe car and wire extensions works well too. Spacer is hit or miss. I prefer the options in the order I listed regardless if it was said to not tune. Headers are crap without a tune. These aren't big block V8's.
#10 |
Boosted
Drives: Not a supra....yet
The o2 spacer does not always work PERIOD
| E-Brake issue "clunking noise" when pulling the e-brake while rolling. | Kinzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 06-20-2018 10:14 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 03:58 AM |
