| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2016 Subaru BRZ
Does this sound like clutch chatter?
So this is my 3rd clutch I’m at 108k miles I got a southbend stage 2. Before I had an ACT Street kit. And before that was stock. I can’t tell if this is normal clutch chatter or if it’s TOB noise. https://streamable.com/9fn8fj
#2 | |
Drives: Bone stock
Sent from my SM-F936U1 using Tapatalk |
#3 |
#4 |
Drives: Bone stock
Might be throwout bearing fam.
#5 |
#6 |
Did you replace the front bearing retaining cover at either of the 2 other clutch jobs?
#7 |
Drives: 2013 frs base
If you could, try to get a better recording of the sound. Maybe I'm old and my hearing ain't what it used to be, but I couldn't hear anything other than engine and air noise.
Also, a bad TOB usually makes the most noise with the clutch pedal depressed. |
#8 |
#9 |
#10 | |
Unfortunately my car has catless headers and a catback exhaust so it’s going to be loud. The only way I can make the noise is when driving. It doesn’t make it at idle. It kind of sounds like rattling kind of like a maraca which makes me think it’s just clutch chatter but idk. It also only happens in higher gears. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Howaitoguru For This Useful Post: | blsfrs (10-13-2023) |
#11 |
Flywheel, release arm spring, Release Brg. Clip, that’s it. Says Remove and replace clutch, customer has aftermarket flywheel, clutch fork, and pivot, inspect upon removal. Replace if necessary. The one before that says remove and replace clutch, clutch fork, pivot and springs, and flywheel. Has the same parts. I currently have a Stage 2 Daily kit from south bend. Sent from my iPhone using Tapatalk |
#12 | |
#13 | |
#14 |
| Clutch chatter or nah? | kt45 | Issues | Warranty | Recalls / TSB | 2 | 10-09-2016 12:27 AM |
| Clutch chatter | brzydk | Engine, Exhaust, Transmission | 7 | 10-05-2016 12:31 PM |
| Bad Idle, stalling, clutch chatter, gear lockout, failed clutches: My story and fix | Pneub | Engine, Exhaust, Transmission | 11 | 08-05-2016 10:29 AM |
| Clutch, LW flywheel and chatter.... | wootwoot | Engine, Exhaust, Transmission | 20 | 11-17-2014 03:50 PM |
| Clutch Chatter & Traction Control? | Fortney | Issues | Warranty | Recalls / TSB | 9 | 10-23-2012 11:43 PM |
