Old 06-16-2016, 06:10 PM   #1
brzydk
Drives: 2015 BRZ premium (white)
Clutch chatter
So my car has 16,700 miles on it now. It is bone stock and I have never auto X it or anything. Occasionally I like to do some pulls, shifting at almost redline. And when i shift i do it fast (not power shifting tho) and as im getting back on the gas and letting off the clutch, it chatters and kind of has a deadspot where it wont really accelerate for a second before it engages again (not clutch slipping). this also happens when im in a gear coasting and when i get on the throttle itll chatter a lil bit before taking off
can someone help me out please
brzydk is offline   Reply With Quote
Old 06-17-2016, 01:01 AM   #2
humfrz
Welcome to our forum..........
Does what you call "chatter" feel like a clutch disk slipping (revs go up, but car doesn't move any faster) ....... or, the engine is hesitating (revs don't go up)..??
humfrz
Old 06-17-2016, 11:10 AM   #3
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Seems like a pretty common quirk around here. You could be shifting into too high a gear at too low an RPM. At low RPM the FA20 is a pretty gutless engine producing almost no torques. Couple that with a drive by wire throttle that has a bit of hesitation upon depressing the pedal, and you're gonna have the car feeling like it's broken if you engage the gear at anything below 2.5k RPM (not shifting just to clarify, I mean the gear you're shifting into engaging at 2.5k).
Apart from that, you also have to consider how little noise dampening this car has, so you could very realistically just be hearing normal mechanical components that you would otherwise not hear in a car with proper sound deadening.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 10-05-2016, 02:26 AM   #4
benzz280
Drives: Toyota 86
Reviving an old thread, I too hear a brief chattering noise when shifting up at redline and doing it fast (letting off clutch and gas in). OEM clutch btw. Been wondering if this is normal too. No noise whatsoever shifting at any other rpm though.
benzz280 is offline   Reply With Quote
Old 10-05-2016, 12:06 PM   #5
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
same thing happened to me, revs go up but speed doesn't catch up, i went to get a dyno done and they couldn't because my clutch is worned down, you have worned down your clutch, time to buy a new clutch, i would buy a flywheel too. you can buy both for around $600.
Dr. BRZ is offline   Reply With Quote
Old 10-05-2016, 12:23 PM   #6
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
A shop might resurface the flywheel.
Fenix is offline   Reply With Quote
Old 10-05-2016, 12:24 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
It's from granny shifting, not double-clutching like you should.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 10-05-2016, 12:31 PM   #8
humfrz
(you deserved that - messen wich newbies minds)
humfrz
Chatter at low rpm when cold Hawk77FT Issues | Warranty | Recalls / TSB 35 12-17-2015 01:50 PM
Valvetrain chatter on KW SC FRS nlowell Issues | Warranty | Recalls / TSB 4 05-03-2015 11:20 AM
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 09:30 AM
Clutch, LW flywheel and chatter.... wootwoot Engine, Exhaust, Transmission 20 11-17-2014 03:50 PM
Clutch Chatter & Traction Control? Fortney Issues | Warranty | Recalls / TSB 9 10-23-2012 11:43 PM
