Old 10-10-2023, 06:09 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Best Wheel Bearing/Hub replacement?
NTN/OEM, MOOG or other? I do like MOOG replacement parts.
I’m considering new rear wheel bearing hubs as a winter project.
I unsuccessfully tried removing the original hubs a couple years back in order to install longer stronger wheel studs. A slide hammer wasn’t available then.
Anyway, after a few summers of lapping those original bearings and studs they could likely use a re-fresh. So, damaging the originals during removal is now not an issue.
Any thoughts which brand is superior?
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 10-10-2023, 09:16 PM   #2
cueball89
Drives: 15 Impreza
I've been using SKF wheel bearings and hubs for my Impreza. Warranty is the longest of any bearing and hub I was able to find. One rear bearing was making some noise after a few thousand miles, no issues or hassle on replacement through Rockauto. Hopefully just a one off, everything has been quiet since.
I removed the rear knuckle and pressed the hub out once. PITA trying to get the angle right to press the hub out. https://www.amazon.com/removal-tool-...98&sr=8-5&th=1 Bought this thing and it's freaking great. Washers are super cheap and bend but the hub still comes out. Make sure to support the suspension with a jack or something solid to prevent from over extending the strut. If you don't support the suspension you will kill the strut.
cueball89 is offline   Reply With Quote
Old 10-11-2023, 09:44 AM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
My understanding is OEM is best.
Then SKF/Timken.
Old 10-11-2023, 01:36 PM   #4
RedReplicant
Drives: None
I can't remember if I've posted about it here, but I initially bought a spare Centric and a spare Timkin. I found the Centrics have a different hub style that aligns with everything I dislike when I look at hubs from other cars that commonly break hubs (Miata, S2000, etc). I will say that the Centric can have studs easily installed/removed without hitting it a bit with a grinder.
I tried the Centric and it only lasted a few events before I put the Timken in its place. I ended up finding a deal on two new OEM fronts that I have as my spares for now.
Long story short, Timken or OEM.
RedReplicant is offline   Reply With Quote
The Following 7 Users Say Thank You to RedReplicant For This Useful Post:
bcj (10-15-2023), blsfrs (10-12-2023), glhs386 (11-19-2024), GrandSport (12-18-2024), Ultramaroon (12-17-2024), ZDan (11-15-2024)
Old 10-14-2023, 12:19 PM   #5
Muskoka800
Thanks all for your input and keep it coming!
As suspected the big name bearing companies are getting the nod. Rock Auto have a good selection and I will also scour Canada for competitive pricing when the time comes.
Old 11-14-2024, 10:18 PM   #6
jamie0404
Drives: Toyota
Both brands are durable, but with your track and performance setup, MOOG could offer a slight edge if you want an aftermarket solution with extra durability. However, NTN might be a better fit if you're after OEM consistency.
jamie0404 is offline   Reply With Quote
Old 12-22-2024, 01:52 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
It's not like OEM is especially durable. Are people having issues with the cheap stuff of ebay? These prices for name brands are ridiculous when you can get a pair of cheap hubs for just over 100 bucks for the fronts and less for the rears.
Old 12-22-2024, 07:36 PM   #8
Anyone know the dimensions of the original bearings? I don't have one to examine?
https://www.skf.com/id/products/roll...s-and-variants
Old 12-22-2024, 08:51 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have a bad one laying around.
Ultramaroon (12-22-2024)
Rear left hub bearing replacement, advice. CB750F Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 01-04-2025 02:06 AM
Throw Out Bearing Replacement? Jviveros2 Arizona 16 04-10-2020 05:10 AM
Wheel bearing replacement question FinallyGot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-31-2020 06:15 PM
Throw out bearing replacement(estimated cost) mintyfresh Southern California 8 01-25-2020 07:41 PM
Wheel bearing? Nylander Issues | Warranty | Recalls / TSB 20 06-08-2015 04:57 PM
