Old 09-23-2023, 05:09 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Throttle problem, maybe
There's a longer version of this on the forced-induction thread, but part of it, I think, might be of interest here
My OBD read 100% throttle correctly before, but now it's reading max 80.8. I pulled the compressor off and cleaned the throttle body, and the butterfly was wide open with the throttle on the floor. But OBD still shows 80.8% throttle. Either the OBD has gone bad, or something else is still affecting my throttle with the butterfly wide open. I wonder what else could be telling it not to produce WOT. I think it would have to be the TPS, TBS or MAF. At least that's all I can think of.
It's a little hard to tell for sure if I'm getting WOT because my ESC is working again and it scoots right along. How ESC stopped working for a time is a story for the other forum.
Qwimby1 is offline   Reply With Quote
Old 09-23-2023, 08:52 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
have you flashed to the stock tune(without the motor running) to verify it's not in the tune tables you're using?
Old 09-23-2023, 10:03 PM   #3
Qwimby1
I haven't tried that, and confess I'd be a little out of my league if I did. I'm concerned that the last time I used the OFT I had a hard time to get it to respond to the tune I wanted. it eventually did. I downloaded all the tunes off of it and have them on file, but I'm concerned about having to switch around.
Old 09-23-2023, 10:52 PM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Not sure what to tell you.
When I see 80%, I immediately think max true throttle position. It's how it's always been on the FA20
Maybe you were looking at a different parameter like commanded throttle, throttle pedal position, or other related throttle position variable
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
soundman98 (09-24-2023)
Old 09-24-2023, 12:44 PM   #5
Qwimby1
Helps to know that. I'll take a look at the other possible readouts on the OBD. The one I've been using is absolute throttle position.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
throttle dip? JDM FRS Issues | Warranty | Recalls / TSB 18 07-07-2013 03:50 AM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
