Old 08-17-2023, 01:56 PM   #1
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
brass vs steel
I placed an order for a M18x1.5 to 1/8NPT adapter to be used for installing a oil pressure sensor in the factory oil galley near the TB.
When looking for TQed specs which I still have not found yet I found a post saying to never use brass in a high vibration area as it will come loose and to always use steel.
"Never use brass or aluminum in a high vibration area. (AKA screwed into a block) Steel is always good."
A quick google search for a steel adapter brought me to killer B. Who also can't tell me the tq specs when asked over email...
Does it make sense to order another adapter ? has anyone had experience with either of these adapters or know the tq specs lol
Brass adapter I ordered
https://www.iagperformance.com/prosp...-ej25-engines/
Steel one
https://www.killerbmotorsport.net/m1...pter.html.html
Thank you
autoracer86 is offline   Reply With Quote
Old 08-17-2023, 02:09 PM   #2
Doesn't matter in that application. The vibration mostly comes into play when the part can flex like a tuning fork. Resonance will kill steel just the same as any other metal but it can tolerate limited cyclic strain indefinitely. Think springs. Can't make a spring out of aluminum or brass.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
autoracer86 (08-17-2023), bcj (08-17-2023), NoHaveMSG (08-17-2023), Teseo (08-17-2023)
Old 08-17-2023, 02:15 PM   #3
autoracer86
Drives: Toyota GT86
Thanks for the reply. The quote came from a thread about this very application not saying the user is correct just saying
Old 08-17-2023, 02:18 PM   #4
No sweat. One would go insane chasing after all the misinformation on this, or any other forum. It's a great discussion.
NoHaveMSG (08-17-2023), soundman98 (08-17-2023)
Old 08-17-2023, 02:58 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've been using brass fittings for over 6 years, no issues yet. One of them I milled a bit even on the 1/8bpst side because my transducer probe wouldn't fit through the original hole. If I was using a straight fitting with a long transducer or temp sensor on the timing cover, i'd probably spring for steel just for the safety. As Ultra said, application is key.
You can also just search 1/8pst thread torque and get a generic spec. Most of the time this is good enough.
https://www.engineersedge.com/hardwa...tion_13424.htm
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
autoracer86 (08-17-2023), soundman98 (08-17-2023), Ultramaroon (08-17-2023)
Old 08-17-2023, 03:16 PM   #6
autoracer86
Drives: Toyota GT86
I think you said 9-10ft a few years ago. That was the only thing I could find really lol. I guess most just yolo it.
I will start and 10 and check for leaks.
Old 08-17-2023, 03:56 PM   #7
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
https://ajaxsprings.com/springs/material/brass-springs/
The Following User Says Thank You to gen3v8 For This Useful Post:
Old 08-17-2023, 03:58 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It should be around 1 ftlb depending on how you seal it. You don't want to get it too tight and damage it or pull threads. I know here at work 1/4npt brass in aluminum we do 18 in-lb. It's tapered so it locks up quick without much torque.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Old 08-17-2023, 04:27 PM   #9
Originally Posted by gen3v8 View Post
smartypants
gen3v8 (08-18-2023), soundman98 (08-17-2023)
Old 08-17-2023, 05:21 PM   #10
autoracer86
Drives: Toyota GT86
1ft pound ?? Just 1 lol I think 10 is the lowest my tq wrench goes lol
Old 08-18-2023, 12:25 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you go off the chart I linked, it is 2-3 turns past finger tight with sealant. I have in-lb torque wrenches for things like fittings.
Old 08-18-2023, 01:50 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
smartypants
Nah. Even I knew you were wrong. :p
https://www.americanelements.com/alu...ring-7429-90-5
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ultramaroon (08-18-2023)
Old 08-18-2023, 02:08 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Aluminum and brass springs are very limited use. Brass isn't uncommon as a spring but it has to be heavily alloy'd.
Old 08-18-2023, 04:33 PM   #14
Ok ok... Can't make a typical spring out of aluminum or brass.
Kobe Steel Joystick Off-Topic Lounge [WARNING: NO POLITICS] 26 11-06-2017 07:04 AM
Stainless steel header vs mild steel header interest mav1178 Engine, Exhaust, Transmission 18 03-06-2017 09:23 PM
FS: gold brass knuckle shift knob 86design Interior Parts (Incl. Lighting) 11 01-28-2013 06:30 AM
Steel wheel Silp3 New England 9 01-24-2013 11:14 AM
