Drives: 2013 Subaru BRZ
This morning I was making a 3 point turn on a very narrow road and my back tires hit the grass i slid all the way down into a ditch, tried to get out and the tires just spun. called the towing company and got it towed and went to work.
Once i got to where it was towed to i tried to start it and there was no crank, only the radio and accessories turned on, we tried hooking a battery charger to it and still nothing. any ideas on what it could be? |
#2 | |
Drives: 2015 midnight blue limited edition.
Also have you tried turning the start button on and off multiple times, to prime the fuel pump ? Sent from my Pixel 6 Pro using Tapatalk |
#3 | |
edit: i think i remember it flashing |
#4 |
Yeah so were you able to start it ? I ran into this a couple of weeks ago and I thought it was heat related. I have to let my car sit in the 110 F sun all day while I'm at work and sometimes the car wouldn't start. Drove myself mad. I now think this was due to my key fob going mad. So now, basically, I get in the car, press the clutch and brake, make sure the green symbol is solid and then push the start button. And it fires right up. I have quarantined the other fob and need to get it replaced.
#5 |
the towing company was able to start it, i dont know what they did differently they just said it started fine.
it drives fine tho, both of the bumpers came off when i was in the ditch so im driving around bumperless until i get it fixed lmao |
#6 | |
#7 |
Rust bucket enthusiast
Hmm, is your external temp sensor still dangling somewhere? I doubt it gets used as a reference for any starting tables rather than IAT, but....maybe?
#8 | |
#9 | |
#10 | |
#11 | |
Drives: 2016 BRZ Limited
If you can reach the clutch safety switch area, press down and hold the little button underneath and try to start your car with the clutch pressed down. If the car turns on fine after that, than this might be your issue. I replaced my clutch safety switch and the issue has been resolved. |
#12 | |
#13 |
I'm not too savvy with this stuff but the safety clutch switch makes contact with some button to activate? For me, the car would start fine if I held down that button. If you can replicate this, then I think just the switch is faulty. Any more after that I am not sure.
#14 |
Yeah I don't need to hold it down per se, but I need to press down on the clutch a little longer before I can see the green symbol. Usually connecting and disconnecting the switch and kinda pressing the connector onto the switch fixes it
| Tags |
| brz, towed, wont start |
| 2013 FRS wont start unless battery is disconnected first | KN0W | Electronics | Audio | NAV | Infotainment | 5 | 07-21-2021 09:44 AM |
| FRS Wont Start | CG3TZ | Issues | Warranty | Recalls / TSB | 16 | 10-18-2020 04:40 PM |
| BRZ wont start in hot weather! | Coop | Issues | Warranty | Recalls / TSB | 3 | 06-28-2018 05:24 PM |
| Car wont start? Anyone else? | ScionFrsFan | Issues | Warranty | Recalls / TSB | 150 | 06-09-2017 09:35 PM |
| Car Wont Start Up HELP !!*** | ScionFR-S | Issues | Warranty | Recalls / TSB | 20 | 11-28-2013 01:01 AM |
