Old 08-01-2023, 11:58 PM   #1
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
Will having my toe arm ball joint at this much of an angle cause issues?
Recently I replaced my stock toe arms with SPC arms and got an alignment done. When I got the car back I noticed that the ball joints where the arms go into the knuckles were at a bit of an angle. Is this enough of an angle to cause accelerated wear or other issues?
Stephen02 is offline   Reply With Quote
Old 08-02-2023, 01:15 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's probably okay, it's just lazy work by the shop. There isn't a hex to grab on the ball joint, but it is not difficult to keep parallel to the hub while tightening.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (08-12-2023), Stephen02 (08-02-2023), strat61caster (08-02-2023)
Old 08-02-2023, 02:50 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Is this before or after you put some miles on it?
If before then go put some miles on it and check, if after I wouldn’t be happy with that work. It looks ‘fine’ but odds are the boots will wear and split prematurely shortening the life of the ball joint. And I’m guessing something like 50k miles instead of 75k miles.
ineedyourdiddly
Old 08-02-2023, 04:17 PM   #4
Stephen02
Stephen02's Avatar
About 200 miles. It looked the same when it was first done.
The Following User Says Thank You to Stephen02 For This Useful Post:
Old 08-03-2023, 10:58 AM   #5
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
That's not an issue at all. If it bothers you, reach your hand in there, grab the ball joint, and twist it straight.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 08-03-2023, 11:25 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can't do it by hand when they are tight. The locknut for the outer ball joint needs loosened first. I usually lock the through bolt side first after adjusting toe, then hold the ball joint side with locking pliers while I snug the locknut for that side. Then tighten normally. This has worked for me to keep it from twisting.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (08-12-2023), strat61caster (08-03-2023)
Old 08-11-2023, 07:32 PM   #7
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I did it recently, rotate the axial label, no problem
Ruben_86_ is offline   Reply With Quote
Old 08-14-2023, 08:59 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
With SPC's, the only way it can be done is to undo the locknut.
Old 08-14-2023, 09:16 PM   #9
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
You're right, I thought I was talking about the front axle😅
The Following User Says Thank You to Ruben_86_ For This Useful Post:
NoHaveMSG (08-15-2023)
ball joint leak msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-01-2019 11:17 AM
LCA Upper Ball Joint Issues (maybe?) NAEightySix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 11-03-2017 12:31 PM
Tie rod ball joint stuck Killianti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-19-2015 10:32 PM
Ball Joint Replacement, The fun way. FRSPacNW DIY (Do-It-Yourself) Guides 2 06-28-2014 03:04 AM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
