Old 06-30-2023, 05:32 AM   #1
LeMeteor
Drives: 2013 gt86
How to log cylinder misfire count with an OBD 2 Reader ?
My engine is misfiring at idle, it's very subtle but there's definitely something wrong.
I'd like to log the misfire count but I cannot find that data in my OBD 2 app ( Car Scanner )
I'm guessing I have to add a custom PID or something ?
I also have an OFT, but same, I can't find how to log cylinder misfire count
Thank you
LeMeteor is offline   Reply With Quote
The Following User Says Thank You to LeMeteor For This Useful Post:
humfrz (06-30-2023)
Old 06-30-2023, 06:54 PM   #2
If a code is showing, it should tell which cylinder is misfiring.
Back in the day, we used to pull the spark plug wires off one at a time till the engine speed changed.
Never mind me - It's PAST ma nap time -
Old 07-01-2023, 03:54 AM   #3
LeMeteor
Drives: 2013 gt86
Thank you ! It's not throwing a CEl but I can definitely feel some intermittent vibration and RPM dip at idle (without the AC)
humfrz (07-02-2023)
Old 07-02-2023, 03:03 PM   #4
How many miles on your spark plugs?
If much over 50,000, it may be time for some new plugs.
Old 07-03-2023, 10:00 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
What mods do you have?
1974 TA22 Celica
2013 86 GT
Old 07-19-2023, 09:16 AM   #6
GJR726WY
Drives: 2013 Subaru BRZ
I use Torque with an OBDII bluetooth adapter and it logs misfires by default without a custom PID. It does however take the scan quite a while to display the data, and it's at the bottom of the list.
GJR726WY is offline   Reply With Quote
Old 07-26-2023, 07:23 AM   #7
LeMeteor
Drives: 2013 gt86
Hey guys, thanks for the help
I actually managed to log the Misfire with the OFT, I just had to go back to the settings and set "My car" to GT86
I had a lot of misfires on cylinder 4, changed the port injectors, coilpacks and all of the sparks, it made things slighty better but the problem was still there.
Went back to the garage, changed the direct injector on cylinder 4, now all good
Misfire on cylinder 1 MrScrublord Issues | Warranty | Recalls / TSB 7 01-30-2023 08:30 AM
Cylinder 1 Misfire Under Throttle Butterballz Issues | Warranty | Recalls / TSB 26 09-12-2022 12:03 PM
Logs - Misfire Cylinder #1 Butterballz Issues | Warranty | Recalls / TSB 8 06-06-2021 11:47 AM
HELP P0354 Cylinder 4 Misfire isaiah990 Issues | Warranty | Recalls / TSB 17 12-28-2019 10:38 PM
