Old 06-22-2023, 11:00 PM   #29
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
Originally Posted by Thefalls View Post
I went with the Whiteline subframe inserts and did not really like them. Then changed them to the STI stoppers, I did only the uppers and changed all the subframe bolts to STI ones
(they are longer).
And never looked back ever since.
Is it something like this? https://rallitek.com/products/beatru...-sti-2015-2016
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 06-24-2023, 06:49 AM   #30
Thefalls
Thefalls's Avatar
Drives: Corolla GT
How would you describe the difference between the Whiteline inserts and the STI stoppers?
- Andrew
There was more NVH with the white lines than the STI stoppers. And the behaviour of the car had changed from proper rotation to understeer. And my car was stock, there were no other parts installed.
The rear was so planted that I could not break loose unless i was really trying very hard and I didn't like the change in character.
Then I did a search on the forum and found someone who had installed these STI stoppers and decided to put all four uppers and at the time went with the STI subframe bolts.
This combo was much better. They say that the STI longer subframe bolts work in the same way like the Spoon Rigid collar kits.
This restored the character of the car and decreased the movement/play in the subframe stock bushings to an extent where I could decide when and how much to make the car rotate in a corner.
Hope i am making some sense
Thefalls is offline   Reply With Quote
Old 06-24-2023, 06:57 AM   #31
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Originally Posted by Falkon240 View Post
These STI stoppers are installed on the BRZ Ts from factory.
https://www.ft86club.com/forums/show...=131995&page=2
https://www.ft86club.com/forums/show...=131995&page=4
Some discussions about the STI stoppers.
I preferred to trust the R&D of STI engineers than others.
Here are some part numbers.
https://www.ebay.com/itm/265075640342
Subframe Bushings and Alignment (Toe) gonzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-16-2018 11:06 PM
FS: SuperPro subframe inserts & LCA inner bushings xn7485 Brakes, Suspension, Chassis 1 09-13-2017 03:23 AM
Whos running PBM subframe bushings? ft86xtc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-03-2016 12:31 PM
rear subframe bushings? Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-09-2014 09:25 PM
Whiteline subframe bushings Proof Brakes, Suspension, Chassis 1 03-18-2014 12:14 PM
