Old 01-06-2015, 01:01 PM   #1
gonzo
Drives: frs
Subframe Bushings and Alignment (Toe)
Will installing the whiteline rear subframe bushings throw off my alignment? Just got aligned and the toe was a little off in the rear but still within factory specs. It's zero now but I'm considering installing the whiteline bushings. What are the chances it will throw off my rear toe?
Thanks.
gonzo is offline   Reply With Quote
Old 01-06-2015, 01:10 PM   #2
gonzo
Drives: frs
I meant the subframe inserts, KDT922:
The Whiteline KDT922 inserts (Positive Traction Kit) fill the voids of the factory bushings to dramatically reduce rear cross member misalignment & movement which allows a more positive feel from the rear end during cornering. Inserts are a cost effective upgrade, if you are looking for a stiffer press in option, consider KDT921.
Old 01-06-2015, 02:29 PM   #3
jvincent
jvincent's Avatar
It might change it a little since you are unbolting the rear crossmember from the chassis.
Left and right won't change with respect to each other, so total toe will be the same, but they could change relative to the body.
Old 01-06-2015, 02:30 PM   #4
gonzo
Drives: frs
Since it's not messing with the toe arm I'm going with no.
Old 01-06-2015, 02:30 PM   #5
gonzo
Drives: frs
Thank you! <3
Old 01-06-2015, 03:11 PM   #6
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Looking at the suspension of the BRZ, I'm inclined to say minimally at the worst.
All of the suspension arms are bolted to the subframe, so any movement in the subframe will move the suspension with it. It would be possible to "rotate" the subframe a little bit, and that would result in some rear-steer to one side or the other.
This picture also make me wonder how people are loosening the subframe and shifting it to equalize camber on an otherwise stock car. I'm just not seeing it. The only connection between the suspension and the chassis is the upper shock mount, and that has very little to do with camber (shifting the subframe will change the motion ratios a little bit, raising one side of the car and lowering the other, I guess that would help equalize camber, but to what degree???)
I did the Whiteline inserts few days ago and did notice that the rear subframe mounting holes are slotted (left-right) whereas the front are round.
celica73 is offline   Reply With Quote
Old 01-06-2015, 04:02 PM   #7
wparsons
wparsons's Avatar
^^ I can see shifting the front subframe helping equalize camber, but 100% agreed on the rear.
flickr
Old 01-06-2015, 04:09 PM   #8
jvincent
jvincent's Avatar
This was the point I was trying to make.
The rotation will cause both the left and right toe values to change, but since it is rotating, the total toe (i.e. sum of left and right) would stay the same.
Old 07-16-2018, 11:06 PM   #9
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
The rear-steer is what I am feeling after installing whiteline bushing inserts.
Trueweltall is offline   Reply With Quote
rear subframe bushings? Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-09-2014 09:25 PM
options for solid rear subframe bushings? mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-26-2014 10:30 PM
FS: Whiteline KDT921 subframe bushings jah29 Brakes, Suspension, Chassis 1 05-09-2014 07:50 PM
Whiteline subframe bushings Proof Brakes, Suspension, Chassis 1 03-18-2014 12:14 PM
Whiteline Subframe Bushings problem psyclone07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-08-2014 12:20 PM
