Old 04-05-2023, 07:38 PM   #15
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Good deal. I have STI engine mounts, a Whiteline trans mount cradle, and a set of shifter linkage bushings in my to-do inventory. Maybe one these days they’ll graduate to the been-done inventory. Just need to show them a few YouTube videos so they can install themselves.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-06-2023, 09:49 AM   #16
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Did you guys use loctite when reinstalling the subframe bolts ? If so... blue or red
Thanks
autoracer86 is offline   Reply With Quote
Old 04-06-2023, 10:47 AM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks
No. If anything, I recommend neverseize.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
autoracer86 (04-06-2023), Capt Spaulding (04-06-2023)
Old 04-06-2023, 01:01 PM   #18
Capt Spaulding
Persona Non Grata
I’m squarely with NHM. I recommend antiseize.
The Following User Says Thank You to Capt Spaulding For This Useful Post:
NoHaveMSG (04-06-2023)
Old 04-06-2023, 02:06 PM   #19
autoracer86
Drives: Toyota GT86
Oh what is NHM
Old 04-06-2023, 04:02 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oh what is NHM
Me.
Old 04-06-2023, 04:48 PM   #21
autoracer86
Drives: Toyota GT86
Me.
Haha
Old 06-21-2023, 03:16 PM   #22
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
Thanks for making this thread.
My whiteline subframe bushings are coming in today. I'm also having the PBM diff riser bushings installed... fingers crossed for no headaches...
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 06-22-2023, 10:17 AM   #23
Grivo
Drives: 2014 MT Asphalt FR-S
My subframe + diff bushing combo definitely increased NVH. Although not terrible, it is noticeable. I have a distinct "hum" around the 3k rpm range, however, the driving benefits outweigh the noise increase.
Grivo is offline   Reply With Quote
The Following User Says Thank You to Grivo For This Useful Post:
strat61caster (06-22-2023)
Old 06-22-2023, 02:20 PM   #24
Racecomp Engineering
I have the Whiteline subframe inserts and diff inserts.
Doing some exprimenting, I just removed the front lower diff inserts and made a large reduction in noise for my car.
- Andrew
Thefalls (06-22-2023)
Old 06-22-2023, 03:05 PM   #25
Thefalls
Thefalls's Avatar
Drives: Corolla GT
I went with the Whiteline subframe inserts and did not really like them. Then changed them to the STI stoppers, I did only the uppers and changed all the subframe bolts to STI ones
(they are longer).
And never looked back ever since.
Thefalls is offline   Reply With Quote
Old 06-22-2023, 03:22 PM   #26
(they are longer).
How would you describe the difference between the Whiteline inserts and the STI stoppers?
- Andrew
Old 06-22-2023, 04:10 PM   #27
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I have the subframe inserts and diff inserts.
- Andrew
Same for me. The front bushings on the diff are brutal. I pulled both upper and lower, but the lowers seemed to be the majority of the noise.
The Following User Says Thank You to DocWalt For This Useful Post:
Racecomp Engineering (06-22-2023)
Old 06-22-2023, 04:48 PM   #28
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
I'll add my experience...
I installed only the Parts Shop Max solid diff risers, and went from breaking an axle every drift event to not breaking one in 10 events and 5000+ miles. Minimal NVH increase.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Subframe Bushings and Alignment (Toe) gonzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-16-2018 11:06 PM
FS: SuperPro subframe inserts & LCA inner bushings xn7485 Brakes, Suspension, Chassis 1 09-13-2017 03:23 AM
Whos running PBM subframe bushings? ft86xtc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-03-2016 12:31 PM
rear subframe bushings? Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-09-2014 09:25 PM
Whiteline subframe bushings Proof Brakes, Suspension, Chassis 1 03-18-2014 12:14 PM
