Old 06-19-2023, 12:05 AM   #1
jbug187
Drives: 2022 Subaru BRZ Limited MT
Shifting Down Two Gears on Track
I was up a Lime Rock Park for a track day last week. When coming to the end of the main strait, I had been slamming on the brakes and heel-toeing from fourth to third gear going in to Big Bend. I was getting quicker as the day went on, and was eventually reaching the top of fourth gear about half way down the main strait. The rev limiter would beep, but instead of shifting into fifth, I would keep it in fourth, lift off the throttle to prevent the RPMs from going any higher and just maintain speed until the end of the strait (see video below at the 11:11 mark). I think there's more speed to gain if I shift into fifth gear on the main strait, but I'm not sure how to get back down to third at the end of the strait when going into Big Bend.
Sometimes, when braking and heel-toeing from fourth to third, the rev limiter will beep because of the blipped rev matching. If I tried to do the same from fifth to third, I'm afraid I could damage the engine Should I just brake longer before I try the heel-toe blip from fifth to third? Any advice on the best way to handle this would be appreciated. Bonus points for suggestions on how I can practice recommendations for going down two gears on the road (instead of track) where the stakes a little lower. Thanks in advance.
jbug187 is offline   Reply With Quote
Old 06-19-2023, 12:23 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I just downshift twice (or three times if going from fifth to second like before turn 17 in PIRC). Braking from fifth at 110-120 to reach third gear speeds (50-60) takes enough time to do a heel-and-toe down to fourth and then to third. Doing multiple single gear downshifts also helps prevent money shifting.
If you want to try a single downshift from fifth to third I would wait to do it right before turn in when speed is low enough to not have to worry about a money shift.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
jbug187 (06-19-2023)
Old 06-19-2023, 02:08 AM   #3
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Just skip gears.
SCCA T4 - FRS
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
DarkPira7e (06-20-2023), venturaII (06-29-2023), ZDan (06-19-2023)
Old 06-19-2023, 09:41 AM   #4
Spairo
Drives: 2013 FR-S 6 spd in Halo
Skip shifting is really not a big deal. To me, this is a classic Ford vs. Chevy debate, you will have an equal number of opinions, some of them overly passionate. In the end, it comes down to what works for your rhythm, your comfort, etc. I have been shifting from 5th to 3rd going into T1 on Summit Point for 30 years. Haven't broken anything once.
If you want to try it, you will want to delay your shift so that you aren't revving so high. You can easily practice the motion and the feel on the street. Obviously, if you do so, you won't be doing it with the same speed differentials (at least I hope not), but it will get you used to the motion. Going into slow highway off ramps is a good opportunity to practice.
Have fun. Go fast, take chances
Spairo is offline   Reply With Quote
The Following User Says Thank You to Spairo For This Useful Post:
Old 06-19-2023, 11:16 AM   #5
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
There's a lot ways to skin this cat.
I go from about 105 to 55. I used to just pretend I was downshifting twice (two blips) and go 3-5, without putting it into 4th.
You could always just literally downshift twice.
Then I tried to just brake, clutch in for a second and blip right at turn in and go to 3rd. At the end of the day, I just want to come out in 3rd gear at about 4000rpm or so. I found it was easier to look at it that way. Let the clutch out when I get the rpm up. But with a longer braking zone, the rpm would drop to near idle and it took a lot of blip to get it up high enough while I was trailing off, so I didn't like that. Now I'm back to dual blips.
edit: I can't figure out how to just make it a link that starts at the right time, but at about 1:20 on the lap timer (1:27 or so on youtube) you can hear the "dual blip"
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
The Following 2 Users Say Thank You to GrandSport For This Useful Post:
jbug187 (06-20-2023), strat61caster (06-19-2023)
Old 06-19-2023, 12:07 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
I always skip gears downshifting. No reason not to.
Old 06-19-2023, 04:42 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I always go through the gears because it is what I am comfortable with. No other reason.
Old 06-20-2023, 03:52 AM   #8
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I usually go down 5 to 3 in hard braking on the track, if you do it at the right time it will feel normal
Ruben_86_ is offline   Reply With Quote
Old 06-20-2023, 09:01 AM   #9
jbug187
Great video. I watched the part with the dual blips. I was surprised they came so quickly after you started braking. I'd be nervous going from ~mid 5th gear into 3rd without giving more time to drop speed. I guess I need to force myself to try a quick double shift and also going strait from 5 to 3 and see what works best for me. Thanks.
Sent from my Pixel 7 Pro using Tapatalk
Old 06-20-2023, 02:47 PM   #10
GrandSport
GrandSport's Avatar
I can't take all the credit. My ECU does it, but I also do it. Basically as soon as I brake I blip it once and then shortly after. I never rely on it. I dont let the clutch out. I just want to keep the revs up since it's a long braking zone to go from 105 to 55 or so. Most braking zones are half that drop.
Because of the long braking zone, if I just clutch in the whole time, at the exit of the turn when I'm ready to let the clutch out, revs are all the way down at idle and I need to bring them all the way up to 4-5k. Two blips get it up higher/keep it up over a longer clutch-in time. IDK, maybe it's just my proficiency, but I had trouble getting the revs up from just about nothing all the way up to 4-5k at the end on a single blip- especially while I'm trying to trail off.
Old 06-21-2023, 06:54 PM   #11
CSG Mike
CSG Mike's Avatar
I don't skip gears. Let each synchro do it's share of the work.
Old 06-21-2023, 10:38 PM   #12
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Help me out. I don't understand what the work of one synchro has to do with the work of another.
When you are down shifting and you are going to end up in 3rd gear anyway, say at brake marker 1, why does it matter if you go from 5th to 3rd or 4th to 3rd? Either way, the 3rd gear synchro must still do the same work.
Old 06-21-2023, 11:35 PM   #13
CSG Mike
CSG Mike's Avatar
5->3 makes the 3rd gear synchro do much more work than 5 -> 4 -> 3, because the synchros bring the midshaft (input shaft) up to speed.
engine -> clutch -> midshaft -> synchro -> transmission (wheels)
going into 4 first, lets the 4th gear synchro do some of the work, and then going into 3rd next lets the 3rd gear synchro do the rest of the work.
Pretend you're driving an unsynchronized transmission, and have to double clutch, and it'll make way more sense. A 5->3 shift in this case requires a BIG blip, rather than two smaller blips of 5->4->3.
blsfrs (06-22-2023), DocWalt (06-22-2023)
Old 06-22-2023, 01:40 AM   #14
rice_classic
Bro.. 5-3 is fine, you just gotta love her the right way.
In all seriousness, with technique, I contend the gear skip is no more work on the synchro as you let the revs fall lower and if you double clutch then it’s no work on the synchro.
Edit.. for the avg person, who doesn’t take into account how a transmission works then one can expect extra work on the synchro as a result.
2nd edit: coming from my previous race car with a cable throttle and lighter flywheel, I find the FRS is easier to skip gears as a “big blip” is easier on a double clutch than a small one. This also is in part due to the mods on the pedals as well.
SCCA T4 - FRS
blsfrs (06-22-2023), DocWalt (06-22-2023), ZDan (06-22-2023)
Problem Shifting into gears. itzryry Issues | Warranty | Recalls / TSB 6 01-25-2018 08:19 PM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 02:54 AM
Squeaks when shifting gears/happens every 15 or so seconds while holding speed Simon99 Issues | Warranty | Recalls / TSB 10 10-11-2014 04:54 PM
AFR leaning out after shifting gears Toyota John Software Tuning 14 05-23-2014 02:05 AM
Clunking gears when shifting? hmkk Issues | Warranty | Recalls / TSB 4 02-19-2014 07:14 PM
