| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#113 | |
Drives: '12 C63 P31, '23 GRC
This topic should be it's own thread IMO. I get the connection, because IF the MR2 ever returns it's almost certainly going to be an EV. But, this should be it's own thread.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| The Following 3 Users Say Thank You to WolfpackS2k For This Useful Post: |
#114 |
The seats in the LYRIQ (and really also ICE Cadillacs) have this already. It buzzes your butte all the time. "Hey, there's something on your left" (left cheek buzz), "Hey, you are on SuperCruise and falling asleep" (full check buzz) or "hey, Supercruise is passing this guy on the left" (another left check buzz).
Should be easy to replace the buzz with something a little more "noticable".
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#115 | |
Drives: Q5 + BRZ + M796
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | FR-S2GT86 (06-17-2023), WolfpackS2k (06-19-2023) |
#116 | |||
The question is, is there really enough of an audience for it?
#117 | |
ProCrastinationConsultant
even in the 86, there's really no mechanical advantage to the manual over the automatic. the automatic with the paddles does everything that the manual technically does. there's absolutely no reason for the clutch other than driver engagement.
#118 | |
Master Collaborator
Driver engagement and integrating yourself as a part of the machine, becoming one with it. You simply don't get that experience with an A/T. Hell, I even manually shift the automatic vehicles that I drive. Manual transmissions are also less expensive, less complicated and easier to maintain and repair. Nobody rebuilds automatics anymore, and if you CAN find a shop to do it, it's super expensive. I've never had to rebuild a transmission, but I could probably pull off rebuilding a M/T in my own garage with the right tools. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | WolfpackS2k (06-19-2023) |
#119 |
I've had multiple AT on the family vehicle that have outlived the engine at over 250K miles with just normal maintenance. Only ever had to rebuild one and that was because my son accidentally poured engine oil in it and didn't tell anyone (actually just didn't realize he had done it).
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 06-19-2023 at 07:43 AM. |
#120 |
i had an auto partly rebuilt. it was about $2500 about 10 years ago
one of the wave springs was known to delaminate within the trans, and the pieces would grenade the trans pump. had to pull apart, clean the entire thing, replace the wave spring, replace the torque converter(due to it's fluid capacity, to ensure that all the rogue pieces were removed, replace the trans fluid pump..
| The Following User Says Thank You to soundman98 For This Useful Post: | Dadhawk (06-19-2023) |
#121 |
Drives: GT86
While I'm not averse to the idea of an MT EV, changing gears manually on an electric motor doesn't sound like it would have the same sort of feel or connection as doing so with an ICE, and i'd imagine one of the biggest reasons why EV are automatic when they have a transmission system is because they by their very nature have to stretch every last mile out of the battery, and regenerate battery whenever possible, both things that would be impacted pretty hugely by a manual transmission.
#122 | |
| Reading Tire Pressures Real Time via TPMS Sensors | Bluesman62 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 01-26-2026 05:32 PM |
| OBDII/iphone app combo for real-time monitoring? | CaptainSlow | Electronics | Audio | NAV | Infotainment | 1 | 07-28-2014 07:29 PM |
| BeamNG - Real Time Vehicular Physics Simulation Engine | mikeTee | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 08-07-2013 08:22 PM |
| 86 (FR-S) vs BRZ real-time comparison on Tsukuba circuit attack by Nakaya | yajin | FR-S / BRZ vs.... | 98 | 05-03-2012 08:20 PM |
