#43 |
Drives: 2013 scion frs
Sounds like that’s what it could be after all. I found a clip of one that sounds nearly identical a few minutes ago. Thank you for the reply
#44 | |
Proud of BOXER
Drives: Subaru Boxer
Your car has some cool mods on it, it just needs some TLC.
It would be ideal if there was a Subaru specialty shop local to you that you could take it to!
| The Following User Says Thank You to Clipdat For This Useful Post: | DigitalFootprint (05-05-2023) |
#45 | |
This is the part list sent from the previous owner - Mishimoto performance intake - FT86 Speedfactory unequal length catted headers - Tanabe over pipe - Hooker Blackheart front pipe - Corsa Performance catback exhaust - ACT XT Street Performance Clutch with Lightweight Flywheel - MTEC stainless steel clutch line - Fumoto quick oil change drain plug |
| The Following User Says Thank You to DigitalFootprint For This Useful Post: | Clipdat (05-05-2023) |
#46 | |
Proud of BOXER
Pretty cool, I bet that exhaust is loud but has a satisfying UEL Subaru rumble.
Only thing I would do is remove the intake and go back to a stock intake or a TRD intake. What kind of tune is on the car currently?
#47 |
I eventually want to replace the intake with a stock one. If I have time after the dealership maybe I can hit up a scrap yard and see if I can find a salvage in good condition. As for the tune, I honestly have no idea. I assume it's a stock tune. The previous owner didn't strike me as someone who went too into modding and just stuck with external bits
#48 | |
Proud of BOXER
Cool, sounds like you have a plan!
The only reason I ask about the tune is because with these cars if you just install a cold air intake and/or a header, you aren't going to be even able to fully take advantage of what performance these parts actually bring without a tune of some sort. Especially the intake that's on there, if there's no tune it will actually run worse with it on there versus a stock intake.
| The Following User Says Thank You to Clipdat For This Useful Post: | DigitalFootprint (05-06-2023) |
#49 | |
#50 | |
Proud of BOXER
OFT is extraordinarily easy to use, can't really mess it up. Plenty of threads to search through here about it.
But yeah even if you do decide to tune, I would still ditch the CAI that's on there and go back to good old stock + some kind of drop in filter.
#51 |
Sounds like something to look into! I always assumed tuning was very complicated (I’m sure it is in some cases) but just off the bat from looking into it, the OFT seems like an easy system to use. I’ll look into buying one in the near future! Thank you taking the time to reply!
#52 | |
Drives: 2013 frs base
https://www.ft86club.com/forums/showthread.php?t=151539 |
| The Following User Says Thank You to blsfrs For This Useful Post: | DigitalFootprint (05-08-2023) |
#53 |
That does sound pretty horrible. My guess is tuning issue and it exhaust leak(s)
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
#54 | |
Proud of BOXER
Update?
#55 |
Drives: Crapcan
#56 | |
Proud of BOXER
Hopefully it was a quick fix at the place he took it, and now he's back out on the open road enjoying his ride!
| The Following User Says Thank You to Clipdat For This Useful Post: | DigitalFootprint (08-03-2023) |
| Tags |
| 2013 fr-s, rattling, soot |
| Black soot in exhaust. Normal? | omadab | Engine, Exhaust, Transmission | 37 | 02-03-2019 06:56 AM |
| UEL headers = black soot on exhaust tips? | LaertesSon | Issues | Warranty | Recalls / TSB | 11 | 05-13-2016 09:46 AM |
| high pitched noise when clutch is engaged ( video attached) | jotig | Issues | Warranty | Recalls / TSB | 9 | 07-05-2015 10:22 PM |
| Squirrel noise >1K RPM, Video attached | SubieNubie | Issues | Warranty | Recalls / TSB | 9 | 11-27-2013 12:11 AM |
| Water with black soot in exhaust | KamalT | Engine, Exhaust, Transmission | 17 | 01-08-2013 10:28 AM |
