| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
I thought that at very least those Cup 2's will last some time - but they didn't even do that. When I brought them for tire swap it turned out that rear tires were completely wasted. After just 3 months of usage year ago. And front ones are not much better (like maybe 1.5-2mm tread left till it's gonna hit WI, there's no way they'll make it till end of summer). So not only they grip like sh*t in my use case but don't even survive all that long... Basically my disappointment with those tires is immeasurable and my day was ruined when I had to switch to them. Well Federals on my MX5 are at least cheap so you can say that well yeah, they're crap but good bang for the buck so whatever. But when I was initially buying those Cup 2s I paid for them like 260$ (usd) each due to limited availability in my size so at the end of the day they were expensive af, gripped like sh*t, lasted 3 months. 0/10 Will never buy again... Leaving that rant aside, I talked about this topic with few more friends and people selling tires for competitions and they recommended me Dunlop Direzza 03G in soft compound. But guess what - 03G is actually not made in soft compound in my size (only in sizes that would fit my MX5) so SOL again... What is wrong with soft tires? Why there's almost no soft compound tires with E mark out there? It seems that other options recommended for hill climb and other applications requiring immediate grip are Maxsport and Extreme (in question) which are widely offered in softer compounds... I'm also still a little bit resonating towards Nankang AR-1 since so many people praise their immediate hook up. Even though they look a bit like suicide. Idk I guess I'll try either those VR2 Extremes in soft compound or AR-1 and if they're gonna be too dodgy in the wet I'm gonna think what next... That said now when I think about it, I doubt VR2 will be all that bad since in softer compounds they're marketed as damp tire in the first place. Last edited by lapsio; 05-03-2023 at 07:58 PM. |
#16 | |
Proud of BOXER
Drives: Subaru Boxer
How old are you and how many years have you been driving total?
#17 |
#18 | |
Proud of BOXER
Sounds about right.
#19 |
#20 | |
Proud of BOXER
When I was in my 20s I didn't know dicĸ about shit, but I sure thought I did.
| The Following User Says Thank You to Clipdat For This Useful Post: | worldrallyblue (05-19-2023) |
#21 |
So what's your experience based recommendation in such case? xD I'm here just to hear it. If I wasn't I'd just straight away go and buy what I initially planned without any prior consultation.
#22 | |
Proud of BOXER
My recommendation is put on 17x9 with 245/40 Michelin Pilot Sport 4S and stop driving like a fucking asshole in public.
| The Following User Says Thank You to Clipdat For This Useful Post: | lapsio (05-03-2023) |
#23 |
I actually considered PS4S and wanted to get them back in the day but they weren't available in my size (225/40r18) where I live hence I went with Cup 2 and it was sh*t idea... That said I see that now there's Continental SportContact 7 which seems to be new PS4S and it is actually available in that size so idk... Maybe :T
#24 |
Drives: '23 BRZ
My 0.02: Yokohama A052 with some tread depth are *amazeballz* in the wet.
| The Following User Says Thank You to ZDan For This Useful Post: | lapsio (05-03-2023) |
#25 | |
https://www.adamsandpage.co.uk/motor...%20or%2020lbs. Do they really hook up so fast? Because it sounds quite good actually if it's true... They got my full attention. From what I see they're even sometimes compared to Extreme VR2 in R7A compound so exactly the ones I considered and well... Yoko's are not retreaded tires so I believe should be less sketchy, safer and have more reasonable tread pattern, should work in wet... And wear out extremely fast which I don't care about because that's understandable price for grip. They sound extremely good so far. Something I don't really understand though - people say they wear out quickly... But like, what?... I mean they're TW200. How some TW200 tires could wear out faster than other TW200 tires? isn't like "TW200" the very definition of how fast tire wears out?... Aren't all TW200 tires wearing out at the same speed?... Last edited by lapsio; 05-03-2023 at 11:42 PM. |
#26 | |
Drives: 2018 BRZ
Specifically for the 200 TW category (Extreme Performance) there are the "cheater tires" that behave more like 100TW (in grip and wear) - RT660, A052 and RE-71RS are leading this sub-category. All three are 200 TW but they are about 2 seconds a minute faster than something like RS4 (which is also 200 TW) and wear significantly faster as well. |
| The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post: |
#27 | ||
Drives: '23 BRZ
Unfortunately another in my class ran later in the day in the dry and got me tho :'(Quote:
#28 | |
Awesome! I asked about A052 my friends and it turns out my colleague at work used them back in the day when he was frequently rallying and autocrossing his Saxo and he said it was amazing tyre. So considering that they turn on almost immediately, they're soft, they're not threat to your own and other people's lives in wet... Are there any notable disadvantages of such tires comparing to UUHP? (other than noise, ride comfort, economy, cost and other life comfort bs stuff which is completely irrelevant because racecar goes brr?) I always assumed that main problem with slicks on street and why people discourage using them on street is mostly that they require significant warm up and that they're usually suicide in wet if you go with something without much tread - which seemed to be true for me when I was using hard slicks - Cup 2 and 595RS-R. But soft ones don't seem to suffer from warmup problem and due to softer compound they're typically so-so in wet as well... I already experienced that with Extreme VR1 W5 and Extreme VR3 W3 which worked perfectly fine in street use cases. So I don't see any other disadvantages?... I'd like to form some very oversimplified conclusions regarding usage of motorsport tires on street and for now they go as follows: hard semi slick: - requires warmup (bad) - bad wet performance because of hard compound - dangerous in cold weather + superb and more stable, longer lasting performance in case somehow you manage to warm them up soft track tire: - a bit worse wet performance but in many cases not dangerously bad - still too hard for winter temps - probably fall apart on race track relatively soon + stellar performance + don't require any particularly intense warmup super soft/wet track tire: - melts, cracks and dangerously falls apart in warmer weather - don't work on snow but nobody cares + stellar performance + for me actually required less warmup than winter tyre + works basically as long as temps don't drop significantly below 0 + you don't waste your time choosing radio station because you can't hear anything other than tyres anyways It skips economy/longevity factor of course. For now I have 4 sets of tires that I'm changing depending on temperatures and seasons and I believe it kinda covers full spectrum :T Falken Eurowinter - snow Extreme VR3 W3 - winter without snow (0-30c operating temps) Extreme VR1 W5 - autumn/spring above 0 (20-40c operating temps) and now probably A052 (instead of Cup 2) - summer (40-60c operating temps) Does it sort of make sense or am I still missing something in this general concept or misunderstood something?... (apart from common sense that is) Last edited by lapsio; 05-04-2023 at 08:34 PM. |
| Anthony Bourdain found dead from suspected suicide | unhappymeal | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 06-08-2018 02:11 PM |
| Zestino semi slicks | ulteeb | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-28-2016 03:14 PM |
| Chicago Metra Suicide | TouchMyHonda | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 04-16-2013 09:28 PM |
| Work XT7 18's (white), FZ201 Semi Slicks | kiks | Australia Classifieds | 0 | 12-12-2012 07:13 AM |
