Old 04-27-2023, 06:28 PM   #127
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Originally Posted by Breezer View Post
If the difference is only the back face, then AP 8350 caliper clearance would be affected by moving the spokes inward. This is one reason I would like a known measurement to see if there was a trend in the past manufacturing run. This point of comparison could be moot, because sometimes there is a difference between engineering specifications and production product. Example: Apex couldn't verify my wheel would clear the AP 8350 caliper (13.01.10153 Sprint kit) before I took a leap of faith and found out for myself.
In the image below the gap between VS-5RS 17x8.5 ET44 version spoke and AP 8350 caliper at the narrowest point is less than 4.1mm.
Yeah - that could be tight on the 17x8 ET40! If my calculation is correct, it could be as little as 1.75 mm of clearance.
Tatsu333 is offline   Reply With Quote
Old 04-28-2023, 04:42 AM   #128
Breezer
After more thought, I can see how adding material to the back face to reduce offset would maintain adequate brake clearance, if the spoke profile is unchanged.
Whether offset is achieved via centerline shift or back face thickness, I would think the spokes would poke out more or less depending on wheel width.
Breezer is offline   Reply With Quote
Old 04-28-2023, 11:41 AM   #129
Tatsu333
Yes, but with the wheel rim being 12.7mm narrower, the outside face is 6.35mm closer to the rim centerline, and adding back 4mm with the lower +40 vs. +44mm offset means you still lose a net 2.35mm of clearance, so vs. the 4.1mm of clearance on the 18x8.5 ET44, there's as little as 1.75mm with those brakes.
Again, from what I gather, the face profile vs. the outer edge of the rim is identical for all C2 profile wheels, so the amount the spokes "poke out" is the same for all wheels with the same spec profile, regardless of rim width because the profile is vs. the outer rim edge. The spokes poking out more or less is where the other face profiles come into play, with 1 being the shallowest and 3 being the deepest concavity.
Old 05-10-2023, 07:53 PM   #130
RedReplicant
Drives: None
For some third party thoughts, I had a set of two Anthracite 17x9.5 VS5RS show up today that I'm going to be running with my extra two Anthracite 17x9.5 EC7R as my second set of track wheels.
My scale gave me 16.8lb for the VS5RS and 18.2lb for the EC7R, so pretty nice weight drop there. Not sure how accurate my scale is so the only thing to pay attention to is the nice 1.4lb delta.
Color wise the VS5RS seems a bit different shade than the EC7R but you'd never notice without having them side by side, both look great.
All in all, happy.
RedReplicant is offline   Reply With Quote
Old 05-11-2023, 05:59 PM   #131
Pat
Pat's Avatar
Drives: 2023 BRZ
Courtesy of Massaro Images.
Old 05-11-2023, 07:02 PM   #132
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
APEX Race Parts is offline   Reply With Quote
Old 05-11-2023, 07:20 PM   #133
APEX Race Parts
Originally Posted by OND View Post
Alright, going back to a BRZ after selling my first gen in 2019 and I pledged for a set of 17x8 VS5RS before receiving the car
Can we get a clarification about the 17x8 faces? All the materials indicate they should look the same as 17x8.5, but is that really the case? I have never seen an actual picture of a 17x8 I think, so it would help a lot if you could post some.
Thanks!
Apologies for the delay on responding to this! You can expect the 17x8" ET40 to have a very similar face to our existing 17x8.5" ET44 and 17x9" ET48. If you lined them all up side by side there would be some very minor differences, but ultimately they all fall in the same face profile.
Unfortunately we do not have any real wheel photography we can share of that fitment at this time.
I can confirm that our 17x8" ET40 VS-5RS wheel will clear the AP 8350 (13.01.10147) and AP 8350 (13.01.10153) without spacers. The 17x8" ET40 SM-10RS however does require at least a 2mm spacer on the (13.01.10153) kit specifically for clearance.
We only consider a wheel as clearing brakes if there is at least 3mm+ of clearance from the spoke at the closest point and least 5mm+ of clearance away from the lip at the closest point.
Apologies for us not being able to initially answer your clearance questions, we've done quite a bit of testing for the more popular brake kits for these chassis so should there be any questions regarding those in the future, we should have an answer for you. If we don't and you can provide a brake template for the kit, we can also test it for you that way as well.
Hope this helps provide some peace of mind!
Old 05-12-2023, 09:07 AM   #134
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
I love the blue with silver wheel look! Classy and timeless.
Desertnate is offline   Reply With Quote
Old 05-12-2023, 01:18 PM   #135
Pat
Pat's Avatar
Drives: 2023 BRZ
These are VS5-RS wheels (17" x 9" ET48) with 16mm spacers in front. There is about 2.5 degrees of camber all around.
Old 05-13-2023, 10:40 AM   #136
OND
OND's Avatar
Drives: 2023 BRZ
All these cool pics of VS5RS and wife convinced me to switch to SM10RS at the last hours of group buy. Its gonna be a loong 2 months☹️
OND is offline   Reply With Quote
Old 05-23-2023, 09:27 PM   #137
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by APEX Race Parts View Post
how would this spec fit on a fully stock car? i see mixed responses about 9" wheels clearance (and dont want a lower/stiffer ride). hoping to not have to go down to a 17 just to get an 8.5 for clearance because they look too small to me
lbroskee is offline   Reply With Quote
Old 05-23-2023, 09:53 PM   #138
Pat
Pat's Avatar
Drives: 2023 BRZ
Look at their fitment guide on their website. It's fantastic.
Old 07-15-2023, 02:29 AM   #139
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Took 4 months of waiting, finally got them on.
edit: few more pics
Old 07-17-2023, 07:54 PM   #140
Tatsu333
Originally Posted by Bonburner View Post
edit: few more pics
Looks great man! Thanks for the added pics - I was going to message you to see if you had anything from a front or rear 3/4 angle.
What size tires are you running? I tried to zoom in on one of the pics, but can't make it out clearly.
► APEX | Introducing The All-New Forged EC-7R 5x100 86/BRZ Wheel Line APEX Race Parts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 12-09-2022 03:14 PM
► APEX | Fully Forged Lightweight 86/BRZ Wheels APEX Race Parts Wheels and Tires 59 07-20-2022 12:20 PM
SOLD : Apex EC-7R Forged 17x9 Bronze Wheels MoarGeesPlease Wheels and Tires 5 10-04-2021 09:40 AM
► APEX | NorCal 86/BRZ Needed For Photoshoot With Our All-New Forged EC-7R Wheels APEX Race Parts Northern California 3 07-06-2020 04:05 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
