Old 03-10-2023, 12:05 AM   #113
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Originally Posted by APEX Race Parts View Post
Joe's Scion FR-S
APEX Wheels Forged SM-10RS in Satin Bronze
F/R: 17x10" ET42 with 255/40-17 Maxxis RC-1
Mods:
Front 15mm Spacer
Annex Suspension Clubspec Pro Coilovers (12K/14K)
Cusco Front Lower Control Arms
FIGS Engineering Trac and Toe Arms
Perrin Front Sway Bar
ST Rear Sway Bar
Wilwood 6-Pot Front BBK / Wilwood 4-Pot Rear BBK
Alignment:
-4ºF / -2.3ºR
The bronze finish looks great!
Originally Posted by humfrz
I'm old and lazy
Old 04-11-2023, 02:16 PM   #114
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Featuring the new lightweight SM-10RS...
and fan favorite VS-5RS!
FITMENTS
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: https://apexwheels.com/
Hours: M-F 9a-5p PST
APEX Race Parts is offline   Reply With Quote
Old 04-17-2023, 08:56 PM   #115
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Waiting on the 18" VS-5RS to be available again - I completed missed the first group buy
Old 04-18-2023, 08:26 AM   #116
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
How is the fit of the 17x8 et40 wheels?
Old 04-21-2023, 01:14 PM   #117
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Not the greatest pics... I've gotta clean up the car and install a little longer front studs before I can go anywhere for better pics. Only 5.5 turns of lug nut engagement with 13mm front spacer compared to the 10mm spacer I was using before with the Enkeis, not quite enough!
These are the APEX VS-5RS, 17x9 ET48
Old 04-21-2023, 01:20 PM   #118
Clipdat
Proud of BOXER
Clipdat's Avatar
Is that -3 up front?
I'm old and lazy
Old 04-21-2023, 09:16 PM   #119
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
-4.8
Old 04-25-2023, 11:43 AM   #120
OND
OND's Avatar
Drives: 2023 BRZ
Alright, going back to a BRZ after selling my first gen in 2019 and I pledged for a set of 17x8 VS5RS before receiving the car
Can we get a clarification about the 17x8 faces? All the materials indicate they should look the same as 17x8.5, but is that really the case? I have never seen an actual picture of a 17x8 I think, so it would help a lot if you could post some.
Thanks!
OND is offline   Reply With Quote
Old 04-25-2023, 06:45 PM   #121
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Thanks!
DocWalt's post a few above yours shows the 17x9 ET48, which has the same C2 face profile as the 17x8 ET40, so that should give you a pretty solid idea...
Tatsu333 is offline   Reply With Quote
Old 04-26-2023, 11:51 AM   #122
OND
OND's Avatar
Drives: 2023 BRZ
Yea I saw the pics of other sizes with the C2 face, which is why I joined the group buy, but Im still curious to see an actual set of 17x8s.
Old 04-26-2023, 01:19 PM   #123
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Old 04-26-2023, 03:20 PM   #124
Breezer
Originally Posted by DocWalt View Post
...These are the APEX VS-5RS, 17x9 ET48...
Would you take measurements please? Place a flat edge (example: carpenter level) across the spoke face at its highest spots, then measure the gap to the edge of the rim and to the center cap. This will provide a relative face height/convex profile for offset comparisons. At ET44 the gap is ~9mm to the rim edge and ~50mm to the center cap.
It may be that offset is attained by altering some other dimension, but then spoke height measuring may provide something better than imaginative squinting.
Breezer is offline   Reply With Quote
Old 04-27-2023, 01:09 AM   #125
Tatsu333
I remembered that the folks from APEX had posted a link to their wheel configurator a few pages back. It shows a picture of the selected wheel, and if you scroll down the page it also shows a cutaway to illustrate the face profile. Here's a link with the 17x8 ET40 selected.
*NOTE: Not all the fitments are on the configurator, and there are cutaways for all the listed VS-5RS fitments, but not for the 17" SM-10RS fitments.
From what I gather, a C2 face is a C2 face, regardless of offset - I.E. the spoke shape and convexity / concavity vs. the rim are the same. The difference in offset is added / subtracted on the back face of the wheel hub and machining the bolt holes accordingly.
Given that, the wheel face on DocWalt's car should look identical to a 17x8 ET40, only about 4.7mm further outboard in the rear (due to the 25.4mm additional wheel width divided by two, for 12.7mm on the outboard side, minus the additional 8mm in positive offset, so 12.7 - 8.0 = 4.7). In the front, due to his 13mm spacers, they would actually be 17.7mm further outboard than a 17x8 ET40 mounted without spacers.
Old 04-27-2023, 03:44 PM   #126
Breezer
...From what I gather, a C2 face is a C2 face, regardless of offset - I.E. the spoke shape and convexity / concavity vs. the rim are the same. The difference in offset is added / subtracted on the back face of the wheel hub and machining the bolt holes accordingly...
If the difference is only the back face, then AP 8350 caliper clearance would be affected by moving the spokes inward. This is one reason I would like a known measurement to see if there was a trend in the past manufacturing run. This point of comparison could be moot, because sometimes there is a difference between engineering specifications and production product. Example: Apex couldn't verify my wheel would clear the AP 8350 caliper (13.01.10153 Sprint kit) before I took a leap of faith and found out for myself.
In the image below the gap between VS-5RS 17x8.5 ET44 version spoke and AP 8350 caliper at the narrowest point is less than 4.1mm.
► APEX | Introducing The All-New Forged EC-7R 5x100 86/BRZ Wheel Line APEX Race Parts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 12-09-2022 03:14 PM
► APEX | Fully Forged Lightweight 86/BRZ Wheels APEX Race Parts Wheels and Tires 59 07-20-2022 12:20 PM
SOLD : Apex EC-7R Forged 17x9 Bronze Wheels MoarGeesPlease Wheels and Tires 5 10-04-2021 09:40 AM
► APEX | NorCal 86/BRZ Needed For Photoshoot With Our All-New Forged EC-7R Wheels APEX Race Parts Northern California 3 07-06-2020 04:05 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
