Old 04-12-2023, 09:09 AM   #1
Tozerman
Drives: 2016 BRZ SE
Gearbox HELP..
Hi,
I have a 2016 manual BRZ. I have just started to change the gearbox oil and now have a problem.
Instead of removing the actual drain plug I removed the little plug next to it
There was no sealing washer and looking online at parts diagram there is a little ball above the plug , nothing came out other than oil, no ball, no sealing washer, nothing.
Do I just refit the plug as is or should I fit a crush washer (I have one that would fit)
Library image below, blue arrow pointing to the little plug.
Tozerman is offline   Reply With Quote
Old 04-12-2023, 11:46 AM   #2
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
The plug is sealed with teflon tape or similar, there should be a detent ball in there. If it is missing....I'd replace it. It is P/N: 30099AA350
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 04-12-2023, 02:36 PM   #3
Tozerman
Drives: 2016 BRZ SE
Thanks for the reply.
I am 99.9% sure that no ball came out with the plug, indeed no sealing washer too.
In the threaded hole there is some blue sealant in the threads.
I am inclined to just refit the plug using some Hylomar on the threads.
I have sifted through the old oil in my drain pan and there is nothing in it.
what does the little ball do ? and what would happen if I carried on without it ?
Old 04-12-2023, 02:43 PM   #4
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
It's number 9 in this image. Under the center case.
It looks like its is part of gear shift fork rod #5.
The Following User Says Thank You to dragoontwo For This Useful Post:
Bonburner (04-17-2023)
Old 06-07-2023, 05:07 AM   #5
Tozerman
Drives: 2016 BRZ SE
Update on this.
Researching online and checking the workshop manual I have concluded that the little plug and ball is only used for gearbox assembly only.
It is for this reason that nothing came out when I removed the plug.
I changed the gearbox oil to Fuchs and the problem has gone away. Result
The Following User Says Thank You to Tozerman For This Useful Post:
soundman98 (06-07-2023)
Would you rebuild your gearbox or buy another? radroach Engine, Exhaust, Transmission 20 11-04-2016 10:44 AM
gearbox issues blown Engine, Exhaust, Transmission 4 10-13-2014 03:22 PM
built gearbox? Rocket.BRZ Engine, Exhaust, Transmission 2 09-07-2014 02:28 PM
Gearbox Stiffness? pevangelista Issues | Warranty | Recalls / TSB 3 05-08-2013 02:00 AM
Gearbox Oil os86 Engine, Exhaust, Transmission 1 07-18-2012 03:37 PM
