Old 10-13-2014, 01:58 PM   #1
blown
Drives: ft86
gearbox issues
Anyone have any trouble going into 1st or 2nd from a standstill? Does it all the time cold/hot car on/off the only way it will go in is by lifting up the reverse collar and it will go in..
blown is offline   Reply With Quote
Old 10-13-2014, 02:08 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
Is your shifter/transmission stock? You may need to adjust your reverse lockout plate, or whatever that thing is called.
Old 10-13-2014, 02:09 PM   #3
BRZ'13
BRZ'13's Avatar
Drives: subaru
I have issues when it's cold but never have I had to lift the reverse collar to get it into first and I never start in 2nd gear. For sure take it to the dealer if it happens all the time.
BRZ'13 is offline   Reply With Quote
Old 10-13-2014, 02:19 PM   #4
blown
Drives: ft86
might have to check the TRD shifter.
Old 10-13-2014, 02:22 PM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
Yep I'll bet that's your issue. There may be a thread on adjusting the plate somewhere on the forum, search using google.
built gearbox? Rocket.BRZ Engine, Exhaust, Transmission 2 09-07-2014 01:28 PM
Gearbox Bushing Kit - BEST OFFER HORSEPOWER DIRECT Transmission and Driveline 2 01-08-2014 09:35 PM
gearbox/shifting concern Kosmos Issues | Warranty | Recalls / TSB 9 05-10-2013 08:53 PM
Gearbox Stiffness? pevangelista Issues | Warranty | Recalls / TSB 3 05-08-2013 01:00 AM
Gearbox Oil os86 Engine, Exhaust, Transmission 1 07-18-2012 02:37 PM
