Old 03-24-2023, 12:43 PM   #71
Question, did you order the additional rubber blocks for the pinch welds?
I thought they came with them. I have two sets of four blocks. One a bit taller than the other.
Old 04-07-2023, 03:48 PM   #72
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
SARD FRP wing installed. See my instruction guide below.
SARD Wing Install with OEM Holes Covering
https://r.tapatalk.com/shareLink/top...ink_source=app
spcmafia is offline   Reply With Quote
The Following 3 Users Say Thank You to spcmafia For This Useful Post:
autoracer86 (04-07-2023), NoHaveMSG (04-10-2023), Teseo (01-10-2024)
Old 04-07-2023, 04:31 PM   #73
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Loving the look of the wing. Thanks for the guide as well
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
spcmafia (04-10-2023)
Old 04-10-2023, 07:16 AM   #74
spcmafia
spcmafia's Avatar
Hey thank you, and my pleasure!
Old 04-17-2023, 08:09 PM   #75
spcmafia
spcmafia's Avatar
When in Gettysburg
Old 05-02-2023, 06:59 AM   #76
spcmafia
spcmafia's Avatar
A few updates;
For about a year, the vehicle started making a metallic, ticking noise. It became more preeminent when the vehicle was warmed up, and would only go away whenever applying little to full pressure to the clutch pedal.
I greased everything that I could, did two fluid replacements, nothing changed. Until finally I caved in about the possibility that it might be my throwout bearing (TOB).
So I got all my parts together, and went to work. Mind you this was the very first time I took on a more advanced repair by myself. There were a couple of freak moments, but in the end, after countless thread updates and YouTube videos, the repair was finished. Thread here https://www.ft86club.com/forums/show...28#post3579028
I took the opportunity to change fluids and went with AMSOIL. Probably the best decision I've made regarding Engine, Transmission, and Differential fluids. Everything feels so silky smooth and the car feels so much different. Highly recommend to make the switch.
New parts installed are:
Verus Engineering Clutch Fork and Pivot
Revised TOB (OEM)
Schaeffler Slave Cylinder
Whiteline Transmission Insert
DarkPira7e (05-02-2023), villainous_frx (05-03-2023), weederr33 (05-03-2023)
Old 05-02-2023, 10:24 AM   #77
autoracer86
Drives: Toyota GT86
I switched over to asmoil as well just in the transmission at the moment. Like you I found it to be very smooth
spcmafia (05-02-2023)
Old 05-02-2023, 07:47 PM   #78
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
A few updates;
Hopefully you replaced bearing retainer when you replaced the TOB.
Jdmjunkie (05-02-2023)
Old 05-02-2023, 08:14 PM   #79
spcmafia
spcmafia's Avatar
I thought it needed to be replaced but it was in pristine condition. I think I caught the TOB way before it would’ve caused any significant damage.
The Following User Says Thank You to spcmafia For This Useful Post:
ichitaka05 (05-03-2023)
Old 05-31-2023, 11:27 AM   #80
spcmafia
spcmafia's Avatar
Bilstein B14 PSS Installed.
NoHaveMSG (05-31-2023)
Old 05-31-2023, 12:58 PM   #81
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No more wheel gap
spcmafia (05-31-2023)
Old 05-31-2023, 01:34 PM   #82
spcmafia
spcmafia's Avatar
No more wheel gap
Thought of you <3. I'll upload pics once I get the alignment done today.
Old 05-31-2023, 04:05 PM   #83
spcmafia
spcmafia's Avatar
spcmafia 18 BRZ
No more wheel gap
So… the shop that I brought the car to get the alignment outright denied to do the work because of their lift? Fearing it would bottom out.
Old 05-31-2023, 04:35 PM   #84
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That happens. I would call ahead and ask if they handle lowered cars.
