Old 04-07-2023, 01:49 PM   #43
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by Nfsundrgrnd View Post
Got the Log right here!
https://www.dropbox.com/s/k0uqa9cnq9...Knock.csv?dl=0
No knock correction which is interesting...
buddy you have an advance multiplier of 0.27
your engine is EXTREMELY knocking in various zone all the time
Good thing is the problem is found, just read a bit above
NoHaveMSG (04-07-2023)
Old 04-07-2023, 01:50 PM   #44
tomm.brz
This is currently with the stage 1 OFT tune as well.
well, the injectors oring were already toasted by the stock tune
So ofc is going to POP loudly also with the stg1 tune
Old 04-07-2023, 01:54 PM   #45
tomm.brz
Here photos also from the tsb bulletin
https://www.ft86club.com/forums/showthread.php?t=41130
Old 04-07-2023, 02:20 PM   #46
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
So I got a video of the knock, you can hear it loud and clear once I put the camera outside. I also logged these blips but gonna need to upload it later.
Sounds almost exactly the same as mine, but I can't replicate it each and every time like you can. But yeah, it sounds nearly the same. Ugh.
Originally Posted by humfrz
I'm old and lazy
Old 04-07-2023, 02:34 PM   #47
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
So replacing the injector O-rings should fix this?
Nfsundrgrnd is offline   Reply With Quote
Old 04-07-2023, 02:37 PM   #48
tomm.brz
yes
and then be sure to have a better tune than your stock's
if you take a video with engine bay open it should be more clear if it s the oring popped
you d possibly hear from which cylinder it comes
Old 04-07-2023, 02:51 PM   #49
Clipdat
Proud of BOXER
Clipdat's Avatar
Maybe mine aren't fully gone yet and I can get away with just flashing to OTS tune and living with it. Cuz this looks like a PITA fix that's above my abilities:
I'm old and lazy
Old 04-07-2023, 02:54 PM   #50
tomm.brz
yes it is a bit technical the swapping, also need to buy 4 original oring and to mount them you need a special tool that Subaru/toyota sell
Old 04-07-2023, 03:05 PM   #51
Nfsundrgrnd
I would've thought they would swap those when they swapped my short block at the dealership last June. But maybe the tune popped the new ones in that time? Or the dealership cheaped out and didn't replace them.
Old 04-07-2023, 03:10 PM   #52
tomm.brz
usually it is not required to swap them, i didn t when i opened the engune, they are not consumable it just happens that with the bad stock tune they destroy
Old 04-07-2023, 03:15 PM   #53
Nfsundrgrnd
Makes sense. How long of a job would this be? Seems like I need a bunch of parts from that video. Might just get the dealership to swap it if it's not an arm and a leg. Hard to work on cars in an apartment parking lot lol.
Old 04-07-2023, 03:21 PM   #54
Clipdat
Proud of BOXER
Clipdat's Avatar
If it was DI seals would it also be making unwanted knocking/popping noises during spirited/hard acceleration say a 10-80 pull?
I'm old and lazy
Old 04-07-2023, 03:31 PM   #55
tomm.brz
usually if a oring is missing it just makes the loud pop on quick blips at any rpm, anyway if in doubt just have someone blip on ur car while you are in the front with bay opened, it s pretty obvious if a loud pop comes from the heads
i ve seen videos even with a small cloud of vaporized fuel fuming out of the injectors some years ago
Old 04-07-2023, 03:36 PM   #56
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
My 23 makes more or less this same sound doing the same thing. Piston rattle knock/clacky sound. Did it off the lot.
fredzy is offline   Reply With Quote
The Following User Says Thank You to fredzy For This Useful Post:
Clipdat (04-07-2023)
Rough idle leads to stall, runs well under load, no engine response on throttle blip gensch Issues | Warranty | Recalls / TSB 8 09-01-2021 09:26 AM
Abnormal noise when throttle blip or WOT shifting evo4g63 Issues | Warranty | Recalls / TSB 48 10-16-2014 09:42 AM
Throttle Blip Hiss Wepeel Issues | Warranty | Recalls / TSB 29 05-31-2014 12:56 AM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 05:37 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 11:52 AM
