#43 | |
Drives: brz 2017 hksv2
your engine is EXTREMELY knocking in various zone all the time Good thing is the problem is found, just read a bit above |
| The Following User Says Thank You to tomm.brz For This Useful Post: | NoHaveMSG (04-07-2023) |
#44 |
#45 |
#46 | |
Proud of BOXER
Drives: Subaru Boxer
Sounds almost exactly the same as mine, but I can't replicate it each and every time like you can. But yeah, it sounds nearly the same. Ugh.
#47 |
Drives: 2013 WR blue sport tech BRZ
#48 |
yes
and then be sure to have a better tune than your stock's if you take a video with engine bay open it should be more clear if it s the oring popped you d possibly hear from which cylinder it comes |
#49 | |
Proud of BOXER
Maybe mine aren't fully gone yet and I can get away with just flashing to OTS tune and living with it. Cuz this looks like a PITA fix that's above my abilities:
#50 |
yes it is a bit technical the swapping, also need to buy 4 original oring and to mount them you need a special tool that Subaru/toyota sell
#51 |
I would've thought they would swap those when they swapped my short block at the dealership last June. But maybe the tune popped the new ones in that time? Or the dealership cheaped out and didn't replace them.
#52 |
usually it is not required to swap them, i didn t when i opened the engune, they are not consumable it just happens that with the bad stock tune they destroy
#53 |
Makes sense. How long of a job would this be? Seems like I need a bunch of parts from that video. Might just get the dealership to swap it if it's not an arm and a leg. Hard to work on cars in an apartment parking lot lol.
#54 | |
Proud of BOXER
If it was DI seals would it also be making unwanted knocking/popping noises during spirited/hard acceleration say a 10-80 pull?
#55 |
usually if a oring is missing it just makes the loud pop on quick blips at any rpm, anyway if in doubt just have someone blip on ur car while you are in the front with bay opened, it s pretty obvious if a loud pop comes from the heads
i ve seen videos even with a small cloud of vaporized fuel fuming out of the injectors some years ago |
#56 |
Mebmer
Drives: Sienna, GR86, TourX
My 23 makes more or less this same sound doing the same thing. Piston rattle knock/clacky sound. Did it off the lot.
| The Following User Says Thank You to fredzy For This Useful Post: | Clipdat (04-07-2023) |
| Rough idle leads to stall, runs well under load, no engine response on throttle blip | gensch | Issues | Warranty | Recalls / TSB | 8 | 09-01-2021 09:26 AM |
| Abnormal noise when throttle blip or WOT shifting | evo4g63 | Issues | Warranty | Recalls / TSB | 48 | 10-16-2014 09:42 AM |
| Throttle Blip Hiss | Wepeel | Issues | Warranty | Recalls / TSB | 29 | 05-31-2014 12:56 AM |
| Metal Grind Sound when throttle blip | JDM-dono | Issues | Warranty | Recalls / TSB | 0 | 11-17-2013 05:37 AM |
| Throttle Blip, and other features? | ashtray | BRZ First-Gen (2012+) — General Topics | 39 | 03-07-2012 11:52 AM |
