#15 |
Drives: 2017 BRZ w/PP
It could be that I'm just some idiot following their instructions, but when I followed the install guide, I had probably 1/3rd of the bottle left. I did a lap around the block and was at the bottom of the dipstick, and topped it off exactly to the full line. Drove some more and it was a little below full so I let it cool, cracked the bolt open to bleed it just a tad and poured the last little bit from the bottle in. It has been fine ever since. I'm actually slightly above the line now, which I think might be from thermal expansion.
I figured they gave you exactly how much you needed + whatever they figure an idiot like myself would bleed. That stuff is expensive. |
#16 | |
Drives: 2013 Subaru BRZ limited
#17 |
Drives: 2014 subaru brz
you have to have help checking the oil have to rev to 2500 and have someone check the fluid
#18 | |
I presume that's the part about the oil will dissipate out of the reservoir quickly mentioned on the manual as to how to check it.. i don't think i need to keep the foot on the pedal at 2k RPM while someone else open the reservoir right? i feel like that would spill out as the oil is rushing into the can? Lastly, is the assumption that the reservoir should not be "Empty" during idle? cuz i assume if its empty you will likely get air bubbles into the supply line as the oil coming in from the return..? |
#19 |
Famous Potatoes
Drives: '15 ultramarine
What shop in San Jose? Lived there 55 years, so curious.
Hate to say, Sounds like mine when it died. If so, it will get louder and louder in the next couple weeks. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | jeepmor (05-09-2023) |
#20 | |
but so far what im getting at it may not be the Rotrex unit making the sound, could be from other things.. |
#21 |
Drives: brz 2017 hksv2
block the pressure source of the bypass valve so that inside remains closed (should be).. pinch it with your fingers
does it still whine? also i d be curious for a video of engine bay while revving stationary |
#22 |
according to Jackson racing yes you have to keep the revs up to 2500 while someone is checking it i ask that question also because i was interested in how to check the level as well
#23 |
also push in on the clutch see if it goes away
#24 |
will try this and check, but looks like it is enough since even when i let off the gas within 10 seconds still shows at max.
#25 |
#26 |
Drives: GR86 2022
Sample set of 2 cars with jr sc...both does not sound like that at all.
#27 |
try to pinch the vacuum hose and see if it disappear when bypass valve is forced closed..
#28 | |
| JRSC install near Massachusetts | Strife | New England | 2 | 03-07-2020 11:58 PM |
| Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) | DarkSunrise | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-30-2017 11:39 PM |
| Tires to help with traction after JRSC install | arren123 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-02-2017 01:13 PM |
| Normal engine sounds | BrianBlueBRZ | Engine, Exhaust, Transmission | 3 | 06-28-2014 12:49 AM |
| BEST of Start Up sounds!! More than 70 Exhaust Sounds! | JPxM0Dz | Other Vehicles & General Automotive Discussions | 5 | 01-08-2014 02:24 PM |
