Old 03-27-2023, 03:51 PM   #15
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by Zardoman View Post
let me check that today and see if its low.
It could be that I'm just some idiot following their instructions, but when I followed the install guide, I had probably 1/3rd of the bottle left. I did a lap around the block and was at the bottom of the dipstick, and topped it off exactly to the full line. Drove some more and it was a little below full so I let it cool, cracked the bolt open to bleed it just a tad and poured the last little bit from the bottle in. It has been fine ever since. I'm actually slightly above the line now, which I think might be from thermal expansion.
I figured they gave you exactly how much you needed + whatever they figure an idiot like myself would bleed. That stuff is expensive.
Old 03-27-2023, 04:09 PM   #16
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
looks like they have a page of instructions how to check the oil level, i want to assume they did it as instructed, but i'll find out when i drive out today. i guess the question would be, is the excessing whining noise coming is usually the sign of low Rotrex fluid?
Zardoman is offline   Reply With Quote
Old 03-27-2023, 04:37 PM   #17
stacyu18
Drives: 2014 subaru brz
you have to have help checking the oil have to rev to 2500 and have someone check the fluid
stacyu18 is offline   Reply With Quote
Old 03-27-2023, 06:17 PM   #18
Zardoman
Zardoman's Avatar
so i followed the last page of the manual to check the fluid, revved for a min at 2k rpm, then jumped out to check it, it was pretty much at max. but as i continue to check it through out the next min, it drops rapidly down to minimum, but Not empty.
I presume that's the part about the oil will dissipate out of the reservoir quickly mentioned on the manual as to how to check it..
i don't think i need to keep the foot on the pedal at 2k RPM while someone else open the reservoir right? i feel like that would spill out as the oil is rushing into the can?
Lastly, is the assumption that the reservoir should not be "Empty" during idle? cuz i assume if its empty you will likely get air bubbles into the supply line as the oil coming in from the return..?
Old 03-27-2023, 06:46 PM   #19
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
What shop in San Jose? Lived there 55 years, so curious.
Hate to say, Sounds like mine when it died. If so, it will get louder and louder in the next couple weeks.
Old 03-27-2023, 07:09 PM   #20
Zardoman
Zardoman's Avatar
i won't say the shop for now since its all speculation, they are willing to help but so far JRSC is not giving any helpful resolution other than let me send the Rotrex unit back to them and they can have Rotrex check it for a nice $350 if there's nothing wrong with it, replace if it's bad.
but so far what im getting at it may not be the Rotrex unit making the sound, could be from other things..
Old 03-27-2023, 07:18 PM   #21
tomm.brz
Drives: brz 2017 hksv2
block the pressure source of the bypass valve so that inside remains closed (should be).. pinch it with your fingers
does it still whine?
also i d be curious for a video of engine bay while revving stationary
Old 03-27-2023, 09:30 PM   #22
stacyu18
according to Jackson racing yes you have to keep the revs up to 2500 while someone is checking it i ask that question also because i was interested in how to check the level as well
Old 03-27-2023, 09:36 PM   #23
stacyu18
also push in on the clutch see if it goes away
Old 03-27-2023, 10:35 PM   #24
Zardoman
Zardoman's Avatar
will try this and check, but looks like it is enough since even when i let off the gas within 10 seconds still shows at max.
Old 03-27-2023, 10:37 PM   #25
Zardoman
Zardoman's Avatar
clutch doesn't affect the noise.
Old 03-27-2023, 11:36 PM   #26
dreamwonder
Drives: GR86 2022
Sample set of 2 cars with jr sc...both does not sound like that at all.
dreamwonder is offline   Reply With Quote
Old 03-28-2023, 03:30 AM   #27
tomm.brz
try to pinch the vacuum hose and see if it disappear when bypass valve is forced closed.. Name:  Screenshot 2023-03-28 092908.png
Old 03-28-2023, 12:59 PM   #28
Zardoman
Zardoman's Avatar
Originally Posted by tomm.brz View Post
try to pinch the vacuum hose and see if it disappear when bypass valve is forced closed.. Attachment 219591
ok let me try that today, fingers crossed!
JRSC install near Massachusetts Strife New England 2 03-07-2020 11:58 PM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
Tires to help with traction after JRSC install arren123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-02-2017 01:13 PM
Normal engine sounds BrianBlueBRZ Engine, Exhaust, Transmission 3 06-28-2014 12:49 AM
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 02:24 PM
