Old 03-27-2023, 12:49 PM   #1
EstrogenCycle
Drives: GT86, Automatic Transmission, 105k
GT86 lags/shakes at idle and at highway
Hello guys
I went to a dealership last week to get the 10 years service with plugs.
They also told there is a leakage at transmission and the front cover. I never noticed anything.
I noticed after the dealership that when i park my car it lags when the temp is at idle. The rpms flucate minimal and then my car shakes. I also noticed when i drive on the highway the rpms flucate sometime and the car lags. It feels like it is going to stall. These problems only occur when the car is at idle temperature. When i start the car in the morning and drive around nothing happens.
I have automatic transmission. And my car is 105k km.
I measured the oil today and i found put it is overfilled. See image: https://imgur.com/a/QyHE31D
Could this excess amout of oil be the reason for this problem ?
Anyone have an idea ?
Thank you for help.
EstrogenCycle is offline   Reply With Quote
Old 03-27-2023, 01:36 PM   #2
tomm.brz
Drives: brz 2017 hksv2
hard to tell with no datalog of it
did you scan dtc? maybe it s misfiring
Old 03-27-2023, 03:28 PM   #3
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by EstrogenCycle View Post
Hello guys
Thank you for help.
Yes, correct the oil level
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 03-27-2023, 04:27 PM   #4
That is a terrible image for us to read. The dipstick is upside down (did the oil run "up?") We can't see how far the oil level is above the full-mark. If it isn't drastically overfilled, then no, it isn't the cause.
Clipdat (03-30-2023)
Old 03-30-2023, 02:34 PM   #5
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Try resetting your ECU first.
  • Unplug the negative battery cable for 20 minutes.
  • Plug it back in and turn on the car without touching the gas pedal.
  • Let it idle for 2 minutes.
  • Turn the car off.
  • Restart and check the idle after it warms up.
Good luck!
MJones_RB is offline   Reply With Quote
Old 04-03-2023, 05:37 PM   #6
radroach
Drives: car
Car lags perhaps because the dealership unhooked the battery and the computer reset?
Also flip the dipstick over and check both sides. Read the side that reads lowest.
2012 Manual GT86 Knocking at idle Kipper Issues | Warranty | Recalls / TSB 16 07-23-2020 04:45 PM
Gas pedal shakes a little when i turn the steering wheel right? Mdulin Issues | Warranty | Recalls / TSB 11 01-29-2019 09:44 PM
2015 BRZ Shakes during burnouts?? SamtheKorean Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 10-15-2018 11:37 AM
RPM drops 200 rpm and shakes when coming to a stop spatcha88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 04-21-2015 08:27 AM
Car Magazines Shakes Down Toyota 86 at Killarney Track ZakD FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 10-12-2012 03:07 PM
