Old 10-11-2018, 11:45 PM   #1
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
2015 BRZ Shakes during burnouts??
Hey guys, I find this forum very helpful with car maintenances, interior, and etc and rn im having some issues with my right rear suspension/ differential?
I own 2015 brz with rays gramlights, lowered spring with hankook ventus v12 evo 2 (265) and during trial of burnout wet/dry surface as soon as wheels start to turn, right rear wheel starts to skip/ vibrate up and down. does anyone know solutions to this problems? im hoping to get new coilovers so i dont have to rely on lowered springs. Also if you have any recommendations for good coilovers and suspension mods help yo brother out with good infos
SamtheKorean is offline   Reply With Quote
Old 10-11-2018, 11:56 PM   #2
RJasonKlein
RJasonKlein's Avatar
Read this thread and come back to us with questions:
https://www.ft86club.com/forums/showthread.php?t=29020
Why do you want to do burnouts in your car in the first place?
RJasonKlein is offline   Reply With Quote
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
CSG Mike (10-12-2018), humfrz (10-12-2018)
Old 10-12-2018, 12:26 AM   #3
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
My 2015 does it too, with factory suspension etc. In the old days we used to refer to it as axle tramp and it only happens at low road speeds when spinning the rear tyres. I get no such effect if drifting, ie. there is a sideways component to the slide, it just spins and slides. If I'm going fast enough, and can spin the tyres on say a wet greasy road in third there is no shake either.
Subsonic is offline   Reply With Quote
Old 10-12-2018, 01:51 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Because it's fun.
RJasonKlein (10-13-2018), Spuds (10-12-2018), Stang70Fastback (10-15-2018)
Old 10-12-2018, 02:14 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
There are lot of compliant bushings for these cars in transmission & suspension for comfort and to reduce NVH. Some of technical design decisions are for safety. They all add up that when your wheels are spinning in burnouts, that several components rattle/shake up a lot.
You can change that, eg. install less compliant aftermarket mounts/bushings, eg. rear subframe, diff, gearbox bushing & mount, engine mounts, but not without increased NVH during DD. Some shaking may be attributed also to two piece drive shaft, which is designed this way to fold in case of frontal accidents, to allow engine move down instead up straight, possibly injuring legs and shaft breaking off and piercing cabin or digging into ground and breaking something else in unexpected fashion. Everything is compromise, so not sure if not that frequent use type warrants compromising other areas.
Old 10-12-2018, 02:19 AM   #6
humfrz
Because it's fun.
you're advocating bad habits to the young-ens, old man.
humfrz
Old 10-12-2018, 02:37 AM   #7
humfrz
Hi ya, SamtheKorean, welcome to our gang -
First off, doing "burnouts" in this car isn't doing it any favors, it's hard on the whole driveline and suspension.
Second off, it doesn't have enough power to impress anyone with a chirp and a puff of smoke.
Third off, you bought the wrong car to do burnouts.
OK, it's old grandpa's med time -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
RJasonKlein (10-13-2018), Tcoat (10-15-2018), Ultramaroon (10-12-2018)
Old 10-12-2018, 07:50 AM   #8
Somerandom18
Drives: 2017 manual BRZ
Get poly or solid bushings for rear subframe and diff mounts. This helped a lot for me. Now only the transmission is shaking like mad instead of the entire car.
Sent from my Pixel 2 XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 10-12-2018, 10:15 AM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
All the people saying not to do burnouts, or you bought the wrong car.... stfu. It's a rwd sports car.
My guess is you're not using enough initial rpm to get it going or your tires are too sticky without enough power. A 265 is a decent sized tire for sure. You're getting what's commonly known as "wheel hop."
Obviously changing bushings will help driveline vibrations, but my guess is not enough power for the tires / road surface.
If you continue to have issues only on one side you can try a different half shaft (available in the aftermarket) on that side.
Although that is a last ditch effort imo several manufacturers actually build different weights / diameters into their axle shafts to combat this very thing.
Old 10-12-2018, 12:13 PM   #10
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
[ame]https://www.youtube.com/watch?v=7f526kO7IMw[/ame]
Old 10-12-2018, 01:30 PM   #11
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Yes stop doing burnouts. I pity the person that buys cars from these guys. The abuse I read about on this forum is frightening.
Old 10-12-2018, 02:00 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Isn't your avatar a picture of your car at a track????
These things are toys. Enthusiasts will use them enthusiastically.
Old 10-12-2018, 06:13 PM   #13
wparsons
wparsons's Avatar
Burnouts and drifting are significantly harder on a car than a track day...
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
TommyW (10-12-2018), Ultramaroon (10-12-2018)
Old 10-12-2018, 06:20 PM   #14
Summerwolf
Panda Trueno
Summerwolf's Avatar
I feel like they're all using the car in a way that it was intended...... track days can be considered abuse by many anyways.
What's worse? A 30 second burnout or multiple track laps at 8/10's? Lots of factors at play.... everyone is going to enjoy the car how they want to.
The Following User Says Thank You to Summerwolf For This Useful Post:
HKz (10-12-2018)
RPM drops 200 rpm and shakes when coming to a stop spatcha88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 04-21-2015 07:27 AM
Like burnouts? Give it some air. D4S Scion FR-S / Toyota 86 GT86 General Forum 24 06-03-2013 07:53 PM
Video - Ebraking and Burnouts Yruyur FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 10-17-2012 12:06 PM
Car Magazines Shakes Down Toyota 86 at Killarney Track ZakD FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 10-12-2012 02:07 PM
burnouts switchkick Scion FR-S / Toyota 86 GT86 General Forum 46 09-07-2012 12:13 AM
