Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-10-2023, 06:34 PM   #1
OldBiker
Drives: 2023 Gray BRZ
Dash Cam Install
New here... just thought this might be of general interest.
Subaru sells a wire harness H501SAJ010 for Gen1 BRZ that also fits Gen2. It connects to the 3-plug wire harness (for optional port-installed auto-dimming/homelink rearview mirror) that sits just above and to the rear of the overhead compartment. (To access, watch videos for installing auto-dimming mirror.) For roughly $10 you will get the proper wire harness.
The white plug connects to the harness... the black one is useless here, cut it off. The STRIPED wire is ACC+ and the black wire next to it is NEG-. Ignore the 3rd wire.
Amazon sells little Buck convertors for 12VDC to 5VDC USB: 2 for $10. Connect one with butt-connectors to the plug. On the other side use whatever USB cable you need for the dash cam. In my case, my VIOFO A119 needed a USB-A to Mini-B connector 2-3ft is plenty long.
The whole power installation fits neatly above the overhead console.
If you do get a VIOFO A119, a couple of notes:
1) The GPS module attaches to the windshield, but lets you simply detach the recorder itself... very handy (and uses a straight in cable, neater than the otherwise 90degree option).
2) The ideal spot is to the immediate right of the mirror stalk. I installed mine a little farther away thinking I needed access for the SD card. That was a mistake, the whole camera detaches readily from the GPS mount, so snug it up next to the mirror.
Cheers
OldBiker is offline   Reply With Quote
The Following 4 Users Say Thank You to OldBiker For This Useful Post:
bcj (03-21-2023), MyHybridBurnsGasAndTires (03-10-2023), removedonut (03-14-2023), Wally86 (03-14-2023)
Old 03-14-2023, 12:28 AM   #2
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
I’m gonna shamelessly self-promote a bit here - i sell these ready-made for $25
https://hachielectronics.myshopify.c...rror-connector
removedonut is offline   Reply With Quote
The Following 2 Users Say Thank You to removedonut For This Useful Post:
Haust (03-14-2023), Wally86 (03-14-2023)
Old 03-20-2023, 11:14 AM   #3
MrH
Drives: 20 Outback XT, 23 BRZ on order
Do you sell a version that splits the port, so those with an auto dimming mirror can add a dash cam?
MrH is offline   Reply With Quote
The Following User Says Thank You to MrH For This Useful Post:
Yoshoobaroo (03-20-2023)
Old 03-21-2023, 11:01 AM   #4
removedonut
I have some connectors to split the port at the mirror end rather than at the 3 pin, but i’ve not built them yet since i’ve been occupied with other projects. The OBD2 port option will work for this purpose though, as long as you have a hardwire kit for the dashcam.
dash cam
DIY: Dash cam install A118-C Paiser DIY (Do-It-Yourself) Guides 14 12-07-2019 03:59 PM
Dash Cam install question 22R Electronics | Audio | NAV | Infotainment 10 11-29-2018 08:15 PM
Nexus 7 DIY dash install Casper Electronics | Audio | NAV | Infotainment 16 01-17-2016 12:28 PM
PST BRZ- Aim MXL2 Dash/Logger Install GSpeed Tracking / Autocross / HPDE / Drifting 33 07-19-2015 08:47 AM
FR-S dash rattle after Injen air intake install Tferritto Scion FR-S / Toyota 86 GT86 General Forum 2 06-29-2014 07:41 PM
