Old 11-27-2018, 06:39 AM   #1
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Dash Cam install question
Hi guys,
I picked up a Thinkware F200D camera. I also bought a hardwire kit. Can I tie into the dome light wiring for this install ? I already have my Radar detector hardwired from there to go on and off with the key but for the canera I need a constant 12v for the park mode. I kinda assume there is a hot 12 for the dome light switch ??? Any help or tips are appreciated.
Thanks,
22R
22R is offline   Reply With Quote
Old 11-27-2018, 08:24 AM   #2
Kaotic Lazagna
Drives: GR Corolla
Maybe look through this thread?
http://www.ft86club.com/forums/showthread.php?t=16300
Old 11-27-2018, 06:38 PM   #3
22R
22R
22R's Avatar
Originally Posted by Kaotic Lazagna View Post
Appreciate the tip.
22R
The Following User Says Thank You to 22R For This Useful Post:
Kaotic Lazagna (11-27-2018)
Old 11-27-2018, 11:26 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by 22R View Post
Appreciate the tip.
22R
For mine I simply have my radar detector and dash cam going into a 12v outlet splitter from the glovebox power outlet. One goes into a LUKAS LK 530 12V UPS, which in turn goes to my rexing v1 dashcam. The other goes to the radar detector. I think the lukas lk 530 no longer exists, but it behaves just like you would expect a hardwired kit to except it doesn't cause a draw on your electricals, and forced the dash cam to record 24/7 rather than a parking mode. This seems like a good replacement:
https://www.amazon.com/VicoVation-Vi...T1N51XYPPK41SM
Althought be forewarned, SD cards are not designed to be constantly streamed to and will eventually corrupt themselves. I've gone through around 3 or 4 64 GB sd cards since 2015 but it's cheap insurance.
Alternatively you could tap and add a fuse to the fuse box for constant 12v power.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
22R (11-28-2018), tobin (11-28-2018)
Old 11-28-2018, 05:10 PM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
If you buy the wrong type of SD card, then sure. If you buy the right type of SD card, then it will last. I've been using the same 64 GB card for more than two years in my dashcam, which has two 1080P cameras, and also runs in parking mode when the car is off. At the time I bought a Thinkware-branded card, but SanDisk now sells their own High Endurance cards specifically for use in dashcams and the like. There are different ways to design the flash memory in an SD card, and higher speed cards typically have a flash structure that makes them wear out much more quickly. A dashcam card doesn't need rear/write speeds of many hundreds of MB/s, so the architecture can be optimized for longevity and durability, rather than high speed. Notice the SanDisk High Endurance cards only have read/write speeds of 20 Mb/s, vs their Extreme Pro cards, which read at 275 Mb/s.
https://www.sandisk.com/home/memory-...urance-microsd
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
reeves (11-28-2018), sharpsicle (11-28-2018)
Old 11-28-2018, 07:21 PM   #6
reeves
Yea you gotta buy the correct type of SD card for dash cams. I've been using mines for 2 yrs with no problems too. SanDisks were notorious for corrupting after repeated recordings, but I guess they might've fixed that.
reeves is offline   Reply With Quote
Old 11-28-2018, 10:38 PM   #7
FRSBRZGT86FAN
I think you misunderstood. In my configuration there is no parking mode, it is simply always on, this continuous use was the cause of the SD card degradation. It would last around 6-8 hours with the car off.
Old 11-29-2018, 09:40 AM   #8
Stang70Fastback
A.K.A. Starlord
Parking Mode IS continuous operation for me as well. I understood perfectly. If you get the right type of SD card it will last for quite a long time
Old 11-29-2018, 06:02 PM   #9
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
SanDisk cards never had a real widespread problem...
Fake SanDisk cards did! At one point it was estimated that over 30% of the "SanDisk" micro-SD cards were counterfeit.
Even today, if you seem to be getting a great deal on a SanDisk card chances are it is fake. SanDisk has articles on their website on how to spot the counterfeits, but sometimes it is almost impossible prior to purchase/use.
Personally, the widespread counterfeiting of SanDisk has led me to avoid them entirely... just not worth the risk with so many alternatives.
FYI: https://www.eetimes.com/document.asp?doc_id=1326059
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 11-29-2018, 07:12 PM   #10
ls1ac
ls1ac's Avatar
Same topic sort of.
Those saving for a good camera, there is an interim solution. Walmart has a camera for under 20 bucks, not many bells or whistles but could save your ass in court.
When you upgrade give it to your mom.
The Following User Says Thank You to ls1ac For This Useful Post:
Stang70Fastback (11-30-2018)
Old 11-29-2018, 08:15 PM   #11
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
You're pretty lucky that using explosive devices like mines inside of your car have caused no problems...
NCtoBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to NCtoBRZ For This Useful Post:
reeves (11-30-2018), ShadowReaper (12-11-2019), Stang70Fastback (11-30-2018)
DIY: Dash cam install A118-C Paiser DIY (Do-It-Yourself) Guides 14 12-07-2019 03:59 PM
Nexus 7 DIY dash install Casper Electronics | Audio | NAV | Infotainment 16 01-17-2016 12:28 PM
PST BRZ- Aim MXL2 Dash/Logger Install GSpeed Tracking / Autocross / HPDE / Drifting 33 07-19-2015 08:47 AM
FR-S dash rattle after Injen air intake install Tferritto Scion FR-S / Toyota 86 GT86 General Forum 2 06-29-2014 07:41 PM
Request: Dash Cam install w/ pics of A-Pillar/headliner 1Cor10:23 DIY (Do-It-Yourself) Guides 13 01-16-2014 07:31 PM
