Old 03-15-2023, 10:46 PM   #1
accokeek88
Drives: frs
ROUGH RIDING 2016 FRS
I'm trying to smooth out my ride
All stock suspension, Firestone firehawks and 27,000 miles on the car
Apparently Toyota altered the 2017 86 suspension and I would like to put that
suspension on my car. How can I find out if those parts will Fit? Anybody done this? I'm not interested in lowering the car.
Thanks
accokeek88 is offline   Reply With Quote
The Following User Says Thank You to accokeek88 For This Useful Post:
humfrz (03-16-2023)
Old 03-15-2023, 11:11 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
while there were alterations to the suspension over time, i don't believe any of the models ever had a softer riding suspension from previous models.
it's always been a performance car that prioritizes performance above passenger comfort.
humfrz (03-16-2023)
Old 03-15-2023, 11:13 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Get some 500tw tires, 205/60/r16 on 16" wheels. Soft as it's going to get.
humfrz (03-16-2023)
Old 03-15-2023, 11:49 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What size tires are on the car currently?
Originally Posted by humfrz
I'm old and lazy
Old 03-16-2023, 12:41 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Me: *laughs in 10/12K spring rates*
In all seriousness. You can check out this thread but you are already about as good as you are going to get spring/damper wise. How many miles on your car? If you are high mile maybe another low miles, or new set, of stock dampers may be worth it. Also what tire? All seasons will generally be softer than summer tires. Going to 16" wheels with a tire with more sidewall also will help.
https://www.ft86club.com/forums/showthread.php?t=123908
soundman98 (03-18-2023)
Old 03-16-2023, 01:06 AM   #6
Thanks
I suggest you reduce the tire pressure down to about 28 psi and see if that helps.
Or, as suggested above, get some "softer" tires (like most all season tires).
Old 03-16-2023, 09:39 AM   #7
Grady
Grady's Avatar
Sell car and buy a 70’s Lincoln Continental.
Put Ohlins on.
The Following 3 Users Say Thank You to Grady For This Useful Post:
g e (10-21-2023), NoHaveMSG (03-16-2023), whataboutbob (03-17-2023)
Old 03-16-2023, 04:41 PM   #8
accokeek88
Drives: frs
Funny you should mention that.
I drove a 1970 Lincoln that belonged to my friends dad.
It was a big beautiful long black car and I could barely see front fenders..
Anyway, the car has 27,000 miles and the tires are 215/45/17's
Looks like I'm leaning towards a smaller wheel
Seems like some of you agree with that to soften the ride
Thanks for your replies
Old 03-16-2023, 04:43 PM   #9
Clipdat
Proud of BOXER
Clipdat's Avatar
The roads got trashed due to the recent rain, you could be feeling the results of that.
I'm old and lazy
Old 03-16-2023, 04:52 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Maybe you need this guy's setup:
I'm old and lazy
Old 03-16-2023, 05:12 PM   #11
Grady
Grady's Avatar
I loved to drive my Grandmas Lincoln. But this was in the 80’s. Her’s was exactly like this one. Yes the front of the car arrived a week before you did. Wish I had it now.
The Following User Says Thank You to Grady For This Useful Post:
Old 03-16-2023, 05:27 PM   #12
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
Tires get significantly harder as they age. Check the date codes on your Firestones - they may have been sitting on the shelf for a while before they were installed on your vehicle.
tarzan_nojane is offline   Reply With Quote
The Following User Says Thank You to tarzan_nojane For This Useful Post:
Clipdat (03-16-2023)
Old 03-16-2023, 05:32 PM   #13
Clipdat
Proud of BOXER
Clipdat's Avatar
Good call, forgot to ask about the age of the rubber.
I'm old and lazy
Old 03-16-2023, 07:53 PM   #14
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
I'm just waiting for it to get closer to when I will remove my winter tires. Then I plan on getting a set of 16" wheels with 225/50/16 Continental ExtremeContact DWS 06 Plus tires to try out for daily use.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Safe to lift BRZ using jacks after riding onto ramp? BNGLDSH BRZ First-Gen (2012+) — General Topics 7 03-04-2018 08:15 PM
Can't stop riding my clutch when reversing DandoX Engine, Exhaust, Transmission 20 09-16-2017 05:40 AM
Mountain Riding SquadRogue Scion FR-S / Toyota 86 GT86 General Forum 24 01-06-2015 07:29 PM
Coasting, brake riding, engine braking paulca Scion FR-S / Toyota 86 GT86 General Forum 17 08-24-2014 06:53 PM
Riding my unicycle and shooting guns MountainManFR-S Off-Topic Lounge [WARNING: NO POLITICS] 0 09-03-2013 09:20 PM
