Old 03-04-2018, 12:00 PM   #1
BNGLDSH
Drives: 2013 Subaru BRZ
Safe to lift BRZ using jacks after riding onto ramp?
Hey guys this will be my first time doing work on my own car, the only problem is because my car is super low, even my low profile jack won’t make it underneath. I want to get my wheels off so I can do some work. Would driving onto a pair of rhino ramps, then lifting the car from that point, removing the ramps and subtituting jack stands be safe to do?
Any info would be appreciated. Thanks!
BNGLDSH is offline   Reply With Quote
Old 03-04-2018, 01:01 PM   #2
oaroyale
Drives: Black BRZ
Yes. However, if your car is too low, it might scrape the rhino ramp on the way up. You also want to make sure you put the ramps back before you lower the car.
oaroyale is offline   Reply With Quote
Old 03-04-2018, 01:28 PM   #3
Brink
Drives: 2017 BRZ
Do you already have the rhino ramps/have you driven onto them before so you know you clear? Like oaroyale said, you might scrape just getting on the ramps if you're too low. Could try something like this:
http://www.ft86speedfactory.com/cusc...universal.html
Low profile ramp and the part of it not supporting the wheel detaches so you can get a jack or jack stand under the car easier without having to completely remove the ramp first.
Brink is offline   Reply With Quote
Old 03-04-2018, 04:18 PM   #4
BNGLDSH
Thanks guys.
I did just purchase the ramps, haven’t received them yet. So I’m not sure about clearance just yet, was thinking of creating some DIY ramp extensions to clear it.
Ah this looks perfect, may have to consider returning the original ramps. Thanks.
Old 03-04-2018, 05:37 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Could have done it cheap and easy with some 2x8's and a 35 degree cut.
Assuming you lift from the center vehicle jack point. And not like some noobs that lifts one side at a time with those silly jack pads
Old 03-04-2018, 06:45 PM   #6
GrantedTaken
Get some wood and pile it like this.
Then jack.
[IMG]https://i.pinimg.com/564x/de/06/e1/de06e178a***7dfbb7a33664fa1ea5fb--car-ramps-garage-diy-car-ramps.jpg[/IMG]
GrantedTaken is offline   Reply With Quote
The Following User Says Thank You to GrantedTaken For This Useful Post:
Spuds (03-04-2018)
Old 03-04-2018, 06:52 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Then jack.
Even a couple of 2x8s (one under each wheel) should get you enough clearance for a low profile jack for any ride height that's streetable. The problem I see may be the back jacking point, since you have to get the jack underneath after the front is already up and tilting the car backwards. Maybe some 2x8s in the back as well?
Spuds is online now   Reply With Quote
Old 03-04-2018, 07:15 PM   #8
ls1ac
ls1ac's Avatar
If jack only misses by an inch then only one board is needed and so on.
because our cars are about 50/50 jacking from the front point will usually lift the back enough to put a board under the back wheel.
wheel stops are a good idea before and behind each tire on the board.
Cusco Jack Assist Ramp Set Evasive Motorsports Mechanical Maintenance and Tools 0 04-17-2015 01:40 PM
Mountain Riding SquadRogue Scion FR-S / Toyota 86 GT86 General Forum 24 01-06-2015 06:29 PM
DIY: Rhino Ramp extenders Laika DIY (Do-It-Yourself) Guides 15 06-22-2014 10:29 AM
Hit the exit ramp rail :( dad&sonFRS Scion FR-S / Toyota 86 GT86 General Forum 123 03-31-2014 11:58 AM
Scion FR-S pushed off a ramp!!!! SUB-FT86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 05-16-2011 11:54 PM
