Old 09-08-2017, 03:29 PM   #1
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Unhappy Can't stop riding my clutch when reversing
I have a bad habit of riding my clutch when I back out (reverse gear). I know Im doing it but I can't seem to stop, I do it because I want to backout very slowly as to not hit anything. If I just go into full gear I feel like Im backing up too quickly. I was wondering if anyone else does this or has some handy advice to help get myself to stop doing this. I dont have a reverse camera, I have the basic '13 pinoeer HU which I love and don't plan on replacing. So that isn't an option.
DandoX is offline   Reply With Quote
Old 09-08-2017, 03:32 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Riding it a little to backup a couple feet is not the biggest deal in the world, BUT: Try using no throttle, and practice in a flat parking lot. Back up using only the clutch, and let it out fully, then slowly apply throttle gently.
It will help you learn how the engagement feels, and what input will give you the desired output.
Also, this is the marketplace. For future reference, there are technical topic boards where you can ask questions.
http://www.ft86club.com/forums/forumdisplay.php?f=8
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 09-08-2017, 03:51 PM   #3
StraightOuttaCanadaEh
Wes
I never use throttle when backing up, just clutch. It's fine!
Old 09-08-2017, 05:50 PM   #4
DandoX
Senior gif poster
DandoX's Avatar
I never tried backing up without using any throttle great tip. I always figured I would just stall and I gave it gas. Totally works and doesn't stall.
Also my bad about creating this thread in the wrong place. If an admin wants to delete it is okay with me.
Old 09-08-2017, 08:24 PM   #5
alan.chalkley
Drives: 4wd zooks
I always have this problem when reverse parking up hills and sydney has plenty of hills.
The reverse gear should have been a lower ratio from the factory.
Who wants to drive backwards fast anyway?
alan.chalkley is offline   Reply With Quote
Old 09-11-2017, 12:57 PM   #6
DandoX
Senior gif poster
DandoX's Avatar
Totally agree. I feel like they did that so the car could execute good j turns, which also helped for commercials and ads. In the real world no one needs to do a j turn unless they are hooning. This gear should be lower ratio.
Old 09-11-2017, 01:44 PM   #7
humfrz
My driveway is uphill and I have to hit the top at a 45 degree angle, so the car won't hi center.
So, I have no choice except to slip the clutch quite a bit, backing out.
I've been doing this for over four years with my FR-S and the clutch still works just fine.
humfrz
Old 09-11-2017, 01:49 PM   #8
Teseo
Drives: frs
At less of 1500 rpms i will not worry about it
Old 09-11-2017, 02:27 PM   #9
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I ride the clutch all the time too, don't feel bad. I put the car in reverse and just give it throttle and once I start moving I press the clutch pedal back in, and repeat as needed until I need to go into first.
I might try some other people's method but the way I do it has been working fine.
Alltezza is offline   Reply With Quote
Old 09-11-2017, 03:50 PM   #10
strat61caster
strat61caster's Avatar
My car is at 62k miles over 4.5 years, I almost always ride the clutch to reverse (quite similarly to @Alltezza in fact), it's rare that I'm moving enough distance backwards to let it out fully and I have no signs of slippage despite hundreds of autox launches on top of me being a knucklehead that's slow to learn. I've stalled it at least dozens of times (don't think I'm at 100+ though) and I've smelled my burning clutch a handful of times as well.
Clutches are tough, the fact that you care and are cognizant of what you're doing means you're probably not doing anything terribly wrong. Yeah, try to be better, but don't sweat it, as long as you can't smell it you're probably not doing any noticeable damage to it.
ineedyourdiddly
Old 09-11-2017, 05:32 PM   #11
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
try backing up on an incline...
Breadman is offline   Reply With Quote
Old 09-11-2017, 05:51 PM   #12
Wes
Yeah, I've done that and it's a bit more finicky. OP wasn't asking about inclines in his original post though.
Old 09-12-2017, 12:33 AM   #13
NRXRaptor
I thought this was normal
NRXRaptor is offline   Reply With Quote
Old 09-12-2017, 12:56 AM   #14
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
If you're just reversing slowly you'll be fine feathering it. Blip and engage/slip the clutch and then clutch in to roll. A few feathers you'll be rolling speed.
If you're going backwards up and incline that's another story, i imagine you'll need to fully engage the clutch to avoid slipping it alot.
blue cat is offline   Reply With Quote
Stiff to engage 1st/reverse from a stop after clutch install mhiscott Engine, Exhaust, Transmission 94 07-19-2020 07:11 PM
Uphill starts: parking brake vs riding clutch for a sec pushrod Scion FR-S / Toyota 86 GT86 General Forum 229 12-20-2015 08:46 PM
Mountain Riding SquadRogue Scion FR-S / Toyota 86 GT86 General Forum 24 01-06-2015 06:29 PM
Riding my unicycle and shooting guns MountainManFR-S Off-Topic Lounge [WARNING: NO POLITICS] 0 09-03-2013 08:20 PM
Is the launch controll tune kind of like riding the clutch? Frsexxxy Engine, Exhaust, Transmission 2 04-29-2013 02:21 AM
