Drives: 2015 Scion Frs
Automatic trans problem need help to diagnose please
So when I’m on 2nd gear in my 2015 FRS base even when flooring the gas. The rpm’s wont go more than 2.5k-3k rpm but when I switch to a different gear say 3rd the throttle is normal and drive like normal. Need help figuring out this problem
#2 |
The Dictater
Drives: '13 Red Scion FRS
Why are your ABS and TC lights on and when did they come on? That's probably one problem right there.
Also, is it just me or are those blinkers flashing faster than usual? I haven't driven mine in 4 months so maybe I'm crazy. Any mods?
Also: "Build Thread" |
#3 | |
This just started happening recently |
#4 |
Have somebody pull the codes as to why you have the lights on. It may have happened 9 months ago but things are escalating and now issues are appearing.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#5 | |
The previous owner decided to change the trans fluid and very shortly after like 1-2days the 2nd gear started to act the way it is currently. I’ve come to a conclusion that the fluid changed fucked it cause everyone knows to not change the fluid if it’s never been done or hasn’t been regularly maintained. So it cause the 2nd gear to slip. But I’d there a way I can fix this. Should I add more fluid or do a whole another fluid change? I don’t know how to come about it |
#6 | |
#7 |
Why does it only slip in one gear? If it was a fluid problem wouldn’t it make all the gears slip? It only slips in 2nd gear. 1st is perfectly normal 100% of the time and anything after 2nd gear is 100% perfect it’s only 2nd gear that has this problem. I’m asking to see if fluid can only cause a single gear to slip only
| Automatic Trans Build FR-S | urban_ninja30 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 09-19-2022 11:52 AM |
| Please help me diagnose a shifting problem | Pat | Engine, Exhaust, Transmission | 22 | 08-05-2019 03:30 PM |
| Automatic Trans Shift During Restrictor | Felix7007 | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 03-19-2015 04:45 AM |
| How to Dyno. automatic trans. | Okieman | BRZ First-Gen (2012+) — General Topics | 1 | 06-25-2014 11:45 PM |
| FRS AVO Automatic Trans Dyno | onzippy | Forced Induction | 14 | 05-30-2014 08:30 AM |
