Drives: 2014 FRS
FRS AVO Automatic Trans Dyno
Posting to sharing my tuning results. @moto-mike set me up with a great tune and the car is sure to be a super smooth daily driver.
Automatic transmission with ~10 psi peak boost, 247HP / 218ft-lbs torque. Entirety of modifications: @AVOturboworld kit w/6psi wastegate spring. NXS manual boost controller. Stock overpipe(not a mod, I know). Tsudo highflow cat front pipe. Flowmaster cat back (discounted from ebay). Jegs 2.5 resonator (to take the rasp out of the flowmaster). [ame]http://youtu.be/jlMYUNiASpo[/ame]
NASA SpecE30 Racer
What was changed between run 002 and run 010? Nice low RPM torque pick up.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#3 | |
Drives: 2014 FRS
002 was the first run of the half finished e-tune from Mike that I drove in with. I couldn't always get new logs to Mike as fast as I wanted because of weather, traffic, work etc. and decided to drive to Moto-east and finish on the dyno. 010 is what I drove out with. Probably could have gotten there, or close, with e-tuning but I needed instant gratification.... so I can change more things.... and do it all over again. |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Thanks for stopping by! Nice to finally drive a turbo AT after tuning a few! These automatics on the FT86 totally blew me away with how they hold the power without slip.
BTW as I'm sure it will get asked, the jaggy lines are simply a result of doing long AT pulls (3rd is too short, 4th is a bit long) with a lousy fan and heat soak. On the street with proper airflow the power will stay smoother. It was hitting 1.71 bar on spool and dropping off to 1.45 by redline. So about 10.5 dropping to 6 psi. Not bad for an AT on pump gas! |
Looks good !
I was actually surprised how decent the autos are in these cars. Not enough to make me get an auto, but still pretty awesome.
Drives: Moped
OP - Any plans to upgrade the trans or get a trans cooler?
Drives: 2014 FRS
Not at the moment. There's a already an oil to water transmission fluid cooler/heat exchanger thing and I haven't seen water temps get much over 200 on the street. The weather is getting a lot warmer now so I'll keep an eye on water along with engine oil temps as we get into summer.
No plans for tracking it either. I'm thinking a standalone EBC to flatten out the boost and a sorting out of my hodgepodge exhaust are next on the to-do list. Thanks |
Drives: 2014 FRS
I just noticed I averaged 36.1 mpg on the 125 mile return trip. That's mostly 75-80 highway with a slight detour through the middle of Manhattan. I hate my gps sometimes.
Go Gators!
Drives: FRS White-out "blown up"
Go automatics!!!!
FA20 Turbo + HRI Tune + FA20 Flex fuel + FA20club intake + SRT headerback exhaust + FA20 headers + KW3's + Hotchkis front and rear sway bars + Cusco strut tower bar + Perrin oil cooler + Perrin pulley & brake stop thingy + GFB water & alternator pulleys + Crawford air/oil separator |
#10 |
Make sure to post to the dyno thread:
http://www.ft86club.com/forums/showthread.php?t=42290
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#11 | |
Drives: 2014 FRS
#12 |
Drives: 2014 FRS
Now that @swift996 pointed out that thread I feel a little underpowered.
![]() Others with the AVO kit are posting much higher number on pump gas like mrfish and even Paul. http://www.ft86club.com/forums/showt...t=42290&page=3 What's up with that? Does the automatic really leach that much? |
#13 | |
#14 |
Drives: 2014 FRS
I'm using the 6psi actuator and a MBC to get ~10 psi but Moto-mike said it was dropping to ~6 psi.
Is there a rule of thumb about spring pressure and and boost controllers? I mean, I've got an 8psi actuator from AVO also so is it better to install that and modulate the extra 2 psi with mbc to get the boost stable? And the driveability is awesome. No complaints there. |
| Is there an Auto Trans only dyno thread? | Pure Automotive | Engine, Exhaust, Transmission | 17 | 07-17-2014 12:35 AM |
| fs: Perrin trans mount and whiteline trans bushing | RWD_FR-S | Transmission and Driveline | 1 | 01-02-2014 05:34 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
