Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: 2013 Subaru BRZ
Non-Coilover option for racecar
Hi all,
My race team has a 2013 FRS we are running and we currently have rebound/height adjustable MCS Coilovers. One of the series we run (ChampCar) does penalty points based on mods, and these coilovers score us a ton of points and penalty laps. We are looking for a sort of cup kit alternative that would save us the points for when we run Champ. I don’t see any full kits, so am mostly wondering if anyone here has experience with different shock/spring combos on track. Thanks!
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#2 |
AutoX-10/10ths every run
I'd start here: https://www.ft86club.com/forums/showthread.php?t=45554
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | Racecomp Engineering (03-05-2023) |
#3 |
Bilstein B6 + RCE Yellow is one option.
Zdan uses B6 + Swift Spec R springs. Are you allowed to run camber plates? - Andrew |
#4 | |
We are, and we do. They are 20 pts per pair, 10 points=1 penalty lap per 8 hours of racing. The MCS coils were getting us 140 points total, a spring/shock combo would be at most 20 points total. Rules on spring replacement: “Suspension Springs, non-OE coil springs are 5-points per corner - Exemption: Vehicles may replace OE coil springs for 0-points provided that the replacement spring: ▪ Is the same shape as the OE spring (straight, frustum, beehive/keg, etc.). ▪ Maintains the exact same ID/OD measurements as the OE spring (+/- 0.25”) when measured at the midpoint and at each end of the spring ▪ Springs may be cut and/or used with spacers (spring rubbers) for no additional points ▪ Shape and measurements must match when the springs are in their original unaltered condition” Not sure if any of your suggested meet the exemption reqs.
Build Thread:
#5 |
I ran OEM 2017+ dampers with peddlers top hats non adjustable and RCE yellows on track. Pretty solid combo. Add camber bolts for more camber if wanted/needed
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
#6 | |
And yeah, the OEM PP dampers do work well too if you have a set laying around or can find a low mileage set for cheap, but the Bilsteins are better and can take more heat. - Andrew Last edited by Racecomp Engineering; 03-06-2023 at 10:06 AM. |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Teseo (03-06-2023) |
#7 |
Drives: '16 BRZ Limited
Depending on how soon you need the springs, I may have a set of RCE Yellows coming off my car hopefully within the next month or so
#8 |
Drives: Toyota 86
I still love my Oem 2017 Base dampers, how many points for sway bars and camber plates? IMO those dampers with a decent camber and a big front bar work really well plus they’ll be easy on tires.
#9 |
The stiffest springs for our cars I believe are the RCE Tarmacs (my springs by discontinued), but unfortunately no springs that go over 300 pounds.
#10 |
Drives: 1980 corvette, 2014 Subaru BRZ
depending on how much money you want to spend I think you can put stock spring mounts on the MCS you have. not sure if that is still legal in your class, but it works for SCCA SOLO.
https://vorshlag-store.com/collectio...brz-scion-fr-s
The Following User Says Thank You to G-Man For This Useful Post: | strat61caster (03-11-2023) |
Full racecar | zberz | Other Vehicles & General Automotive Discussions | 9 | 05-05-2019 06:47 PM |
Best Coilover Option for max low driving | adamg | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 11-18-2014 01:39 PM |
Non-Coilover Option? | djliquidsteele | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 04-20-2013 07:57 PM |
Found a new coilover option from Tein | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 02-22-2013 11:17 PM |
KSport Coilovers - Another Coilover Option | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-15-2012 02:38 PM |
