Old 12-17-2012, 11:22 AM   #1
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Found a new coilover option from Tein
http://www.tein.com/products/street_basis.html
Ride Height Adj Range (F): -1.0~-1.9in (-25~-48mm)
Spring Rate (F): 280lbs/in (5kgf/mm)
Ride Height Adj Range (R): -1.0~-2.1in (-25~-53mm)
Spring Rate (R): 336lbs/in (6kgf/mm)
Uppermount: OEM Uppermount
TEIN Dampers - Street Basis: TEIN Street Basis Damper is the evolution of the popular BASIC coilover model. It incorporates new internal and external components, newly developed coatings and new manufacturing processes.
TEIN engineers have spent many hours developing new seals and internal components to improve durability and product life. This was one of our major goals for the new model.
Newly developed “ZT” coating for improved durability and hassle-free ride height adjustment. TEIN developed this coating in-house after stringent test and analysis procedures. Our engineers tested different coats, application methods, cleaning processes, etc… in our own brine salt water testing machine which simulates heavy solvents/ road salts used in cold weather climates.
Slip-fit threaded adjustment tube. Allows for damper body and threaded sleeve to be thoroughly coated for rust/ corrosion protection.
The slip-fit allows a more thorough coating on the threaded section as well as powder coated damper body.
Revised Aluminum Spring Seat and Delrin Thrust Washer are light weight and durable. This combination allows for smooth ride height adjustment. The new spring seats have a larger contact surface area and eliminate the need for a rubber spring seat
I like the spring rates and the fact it lets me use my stock upper mounts, the price for me is about half of the GC street system i was looking at, i've had good luck with my H tech springs but think these may be in my future.
msrp is $830.00
JoeBoxer is offline   Reply With Quote
Old 12-17-2012, 11:45 AM   #2
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Nice! Great price and a quality coilover you can expect from Tein
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-17-2012, 11:48 AM   #3
JoeBoxer
JoeBoxer's Avatar
The picture is not of the actual FR-S system, haven't seen that yet but will update when i get more info.
Old 12-17-2012, 12:48 PM   #4
JoeBoxer
JoeBoxer's Avatar
And a writeup from MrHeelToe a highly respected vendor on the Acura forums.
http://www.heeltoeauto.com/pitboard/?p=1139
Old 12-17-2012, 01:27 PM   #5
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Great review! I'm Sold
2URGSE
Old 12-17-2012, 02:01 PM   #6
whitejdm
Drives: BRZ prem.
Great find! I wonder how something like this stacks up against the other 800-1100 kits from Fortune etc..
whitejdm is offline   Reply With Quote
Old 12-17-2012, 02:26 PM   #7
JoeBoxer
JoeBoxer's Avatar
I would like to hear from TIC, racecomp, and Strano about what they think but for the price I may just be the guinea pig.
Old 12-17-2012, 02:45 PM   #8
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We just loaded these up the other night on the site.
Got two units in stock now even.
FT-86 SpeedFactory is offline   Reply With Quote
Old 12-17-2012, 02:50 PM   #9
JoeBoxer
JoeBoxer's Avatar
ETA is March 2013
Old 12-17-2012, 02:55 PM   #10
Racecomp Engineering
I went for a ride a while ago on Tein Basics on an STI. The valving was SOFT...and generally comfortable for most roads. However, compression travel was lacking big time, so even medium sized bumps were a little too sharp and very noticeable IMO. For performance they were soft. I'm not sure where I'd put them compared to other low end coilovers like BC/Megan/etc since it's been a little while. For a similar price I'd certainly prefer Koni inserts with good springs for performance but you had to know I'd say that.
- Andrew
Old 12-17-2012, 03:07 PM   #11
JoeBoxer
JoeBoxer's Avatar
- Andrew
The Street Basis is supposed to be an improvement over the Basics but as we all know you get what you pay for. I'm relatively happy with the Tein H Tech springs i have so if they were an improvement over those with stock struts which they would almost have to be they may work out well for me.
I am a little leary just because of the price but i still think they would be better than BC/Megan/KSport...
I'm sure the Koni's in the GC Street setup are a far superior damper and i could get those for about the same price but not sure how they would work with the Tein springs i have.
Old 12-17-2012, 03:14 PM   #12
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
ETA is March 2013
Meh guess I'm back to square one
2URGSE
Old 12-17-2012, 06:29 PM   #13
JoeBoxer
JoeBoxer's Avatar
Not exactly i got 2 sets ordered that will be here in a week or so...
I am getting a vendor account set up so if you are interested in these shoot me a pm. Can't wait to do what I can to help you guys out on parts.
Old 12-20-2012, 06:08 PM   #14
JoeBoxer
JoeBoxer's Avatar
These are shipping to me tomorrow so i will post some pics when they get here.
DG-5 Coilover harajukukei Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-27-2014 03:42 PM
Coilover Suspension Kits! TEIN | Tanabe | Cusco | KW & More! Lowest Prices + FREE S&H AJ@ECSMotorsports Brakes, Suspension, Chassis 23 03-09-2014 11:20 AM
FS: Tein Flex Coilover Jade 86 Brakes, Suspension, Chassis 43 06-15-2013 09:35 PM
KSport Coilovers - Another Coilover Option FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-15-2012 02:38 PM
NW Coilover Shootout DarrenDriven Northwest 14 07-24-2012 02:12 AM
