Old 11-06-2018, 01:14 AM   #43
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Looking for a little advice from those of you that installed a header to the stock overpipe. I got a second hand header without any hardware so I’ve bought the necessary gaskets but I have no idea what size/length of bolts I will need to attach the stock overpipe to the header. Can you help with advice as to what you used?
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 01-05-2019, 04:06 PM   #44
e_lunatic
Drives: 2015 Scion FR-S
I have UEL catless Gruppe-S +flash with stock everything else. So far I like it. it has the rumble but doesn't drone at all. I would like the rumble to be more pronounced but I'm going to get exhaust at some point for that. for now i really like it.
e_lunatic is offline   Reply With Quote
Old 01-19-2019, 11:20 AM   #45
jflogerzi
jflogerzi's Avatar
Originally Posted by stlgrym3 View Post
After one week of daily commute with this setup I think I will go back with aftermarket catback again. Nothing wrong with stock catback, but starting to miss that deep growl once a while. Main targets are quiet catbacks with good build reputation. I’m down to two choices: Perrin 2.5 resonates or CSG Touring 86. I have ACE 350 header and stock front pipe. Which one would you pick?
Here would be my choices
R400
Perrin 2.5
MXP SP/ CSG touring
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 02-28-2023, 10:26 PM   #46
scottbrz
Drives: 2017 BRZ Limited PP
Figured I'd add to this thread since I just put my BRZ back to stock and traded it.
I ran a JDL catless UEL header with the corresponding OFT OTS tune for a while. There were no other modifications on the car (i.e., the rest of the exhaust was stock). I also made the JDL specific valve timing changes that I found on the forum to the tune.
Overall, I liked it. The car was legit faster in almost any scenario. It turned the original three part powerband (initial torque hit, dip, then torque's back...) into a two part powerband with a low and high end. Though, I swear the car lost torque between 2K and 2.5K rpm.
Regarding sound, I can see why some might not like it. It had a bit of a nasal quality to it. Overall, I was cool with it. If I were to do it again, I might go equal length, I'm not sure the uel rumble thing is for me. Regarding volume, a lot of people say it barely increases volume. I'd say it notably increases volume but it isn't too loud. I wouldn't want it any louder, but then again I'm a pretty understated person and like to exercise a vehicle without alerting everyone or drawing attention.
scottbrz is offline   Reply With Quote
Old 03-01-2023, 06:14 AM   #47
KillerBMotorsport
KillerBMotorsport's Avatar
UEL and EL have different sound profiles because of changes in pressure pulse timing. EL is definitely quieter than UEL.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
blsfrs (03-01-2023), scottbrz (03-01-2023)
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 06:18 PM
Aftermarket catted front pipe with stock catback Aenv Engine, Exhaust, Transmission 1 12-07-2014 11:30 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
Aftermarket Catback (Q300) but using the stock muffler. Wise Engine, Exhaust, Transmission 11 10-16-2014 01:42 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
