Old 10-19-2018, 06:57 AM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Anyone runs aftermarket header with stock catback?
I’ve revert my car back to 100% stock except my ACE header and flex fuel kit. I’ve scheduled to remove those next week. But while driving home from the shop yesterday I kind of the sound of ACE header with the stock catback. Has anyone run aftermarket headers with stock catback? Just curious.
stlgrym3 is offline   Reply With Quote
The Following User Says Thank You to stlgrym3 For This Useful Post:
venturaII (10-26-2018)
Old 10-19-2018, 07:07 AM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I remember it being a commonly suggested combo if you wanted a quiet system but an aftermarket header.
Since you like it, why not keep it?
The Following User Says Thank You to Bonburner For This Useful Post:
stlgrym3 (10-19-2018)
Old 10-19-2018, 07:12 AM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
yep i run ace and flex with the rest stock
Breadman is offline   Reply With Quote
The Following 3 Users Say Thank You to Breadman For This Useful Post:
CSG Mike (10-19-2018), stlgrym3 (10-19-2018), SuperTom (10-19-2018)
Old 10-19-2018, 07:26 AM   #4
gpvecchi
gpvecchi's Avatar
Does removing second cat give some power/response?
gpvecchi is offline   Reply With Quote
Old 10-19-2018, 07:34 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Some. Especially if it's only cat removed. But biggest gains come from catless header+tune, as cat placement in stock header for it to heat up to working temps sooner makes it also more negatively affecting performance. Once one already upgraded header & tune, more gains start to hit diminished returns. Also often many leave 2nd header for emissions purpose instead of going fully catless.
The Following User Says Thank You to churchx For This Useful Post:
gpvecchi (10-19-2018)
Old 10-19-2018, 07:51 AM   #6
stlgrym3
I did my custom tuning while having the catless header plus flex fuel kit and aftermarket catback. Now the catback is back to stock do I need a tune revision?
Also somewhat unrelated, if i remove the flex fuel kit altogether l while keeping the aftermarket header do I need a tune revision?
Old 10-19-2018, 09:43 AM   #7
tobin
tobin's Avatar
Drives: '13 BRZ
Hey guys with ACE header and stock exhaust...mind posting some video clips for sound?
tobin is offline   Reply With Quote
Old 10-19-2018, 04:22 PM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
@CSG Mike
He is turbo now, but pretty sure he ran ace with stock catback.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 10-19-2018, 04:41 PM   #9
Code Monkey
Drives: Subaru BRZ
The sound of an ACE header with stock catback is nothing special, sounds really close to stock and is almost as quiet as well. I got a little bit more sound with the CSG Touring 86 Competition catback but again, it is not a sophisticated sound.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 10-19-2018, 04:53 PM   #10
Lantanafrs2
Drives: 2013 frs red
Ofh e85 stock exhaust. Sounds like stock to me. Thank God because road noise is loud enough by itself. Last thing I need is drone.
Old 10-19-2018, 04:56 PM   #11
stlgrym3
So it’s perfectly normal to run stock catback with aftermarket header and tunes. That’s great, now my car feels like a sleeper, sounds like stock 86 but has ace header and flex fuel tune.
Old 10-19-2018, 05:23 PM   #12
strat61caster
strat61caster's Avatar
+1 It's fine and probably the best power/volume ratio out there.
ineedyourdiddly
Old 10-19-2018, 05:43 PM   #13
stlgrym3
Question is do I need to have to do a tune revision when I switch back onto stock catback while still running ACE header and flex fuel kit?
Old 10-19-2018, 06:06 PM   #14
Code Monkey
Drives: Subaru BRZ
Not needed.
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
strat61caster (10-19-2018), Tcoat (10-19-2018)
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 06:18 PM
Aftermarket catted front pipe with stock catback Aenv Engine, Exhaust, Transmission 1 12-07-2014 11:30 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
Aftermarket Catback (Q300) but using the stock muffler. Wise Engine, Exhaust, Transmission 11 10-16-2014 01:42 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
