#394 |
TRACKBREAD
i saw a post somewhere where the hyperflashing was affected by sunlight onto the headlight. The thought was that the LEDs are acting like a tiny solar panel (diodes can do this) and creating a small voltage across them that makes the controller think the resistance dropped so it hyperflashes.
Wish i could remember where this was, maybe the GR86 subreddit? Edit: oh look at that i should have refreshed the page before posting :P |
#395 |
Drives: '22 brz Sport-Tech
Asked ChatGPT if direct sunlight can reverse voltage on an LED:
Direct sunlight can act as a reverse voltage for an LED if the LED is kept in reverse bias condition. This means that the positive terminal of the power source is connected to the cathode (negative) of the LED and vice versa1. In this case, sunlight can generate a small current in the opposite direction of the power source1. This is similar to how a solar cell works2. However, most LEDs have a low reverse breakdown voltage, which means they can be damaged by an applied reverse voltage above this threshold3. The reverse breakdown voltage of an LED is typically around 5 V2. Therefore, it is not advisable to expose an LED to direct sunlight when it is in reverse bias condition. To protect an LED from reverse voltage damage, you can use a regular diode or another LED in parallel with it in the reverse direction. This will limit the reverse voltage across the LED to about 0.65 V or 1.2 V respectively4. |
#396 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
I'm not sure sunlight is the problem. Before I figured out how to toggle the blinkers without causing the hyperflash, I could get mine to hyperflash in the dark.
#397 |
Drives: '22 BRZ
In my experience hyperflash has nothing to do with sunlight and everything with outside temperatures. For me it only happened in the winter and when its gets real cold outside. I don't think I ever had it happen in the summer.
Another culprit could be moisture, I don't have 100% proof but washing the car might affect it too. For some reason many modern cars have issues with condensation inside the headlights and BRZ seems to have that problem too. When I wash the car in the winter and the next day is real cold I notice frost on the inside of the headlight and sometimes I get hyperflashing. |
#398 |
TRACKBREAD
It’s sunlight. Silly LEDs wanna be solar cells:
GR86DOTorg members have fixed the hyper flash with vinyl overlays. Not ideal but it works. https://www.****.org/threads/fast-bl...un.4733/page-9 You have to fix the link after clicking, apparently it’s 2005 and Internet forums are still in the rivalry phase. |
| The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#399 |
Drives: what
#400 |
Well, someone says this exists. New part numbers for the rear lights.
| The Following 3 Users Say Thank You to Xed32 For This Useful Post: |
#401 |
Drives: 2022 BRZ WRB 6MT
Almost 1 year of ownership. 2022 Brought home 5/5/2022 Build Date 4/2022.
At around 1800 Miles, the passenger rear sway bar bushing fell off the bracket. Lucky for me I found it under the car on the parking lot. Kind of weird for being a brand new car. I got under there and reinstalled the bushing. Another 500 miles or so and I can hear a small clunking sound. I look under there and the bushing is 3/4 of the way off and i was able to easily pull it out. Took it to Subaru and they reinstalled it and they mentioned that it may have been a factory torqueing issue. They retorqued the sway bar and end links. 200 or so miles later, it came off again and this time i took it to them without the bushing since im sure it fell off on the highway. Of course, the part is unavailable due to shortages and now i have to wait and NOT drive the car for over a month since they ordered the part. March 6th is the appointment and we shall see if the new bushing will stick. Thought Id share. Miles on the car now is 2800ish |
#402 | |
Drives: what
that's wild, do these cars not have a lip around the edge of the sway bar bushing to keep it retained? |
#403 |
Drives: 22 BRZ limited
They do.
#404 |
Drives: Subaru BRZ
#405 |
Correct. I even did an autocross event without one just to see what it was like.
#406 |
Drives: Subaru BRZ
| The Following User Says Thank You to Code Monkey For This Useful Post: | dragoontwo (03-01-2023) |
| Anyone not buying to avoid early issues like 1st gen FRS? | stocktc1 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 203 | 09-23-2021 09:11 PM |
| Buying an early build in the fall, but some issues with these cars are worrying me... | RyMi | BRZ First-Gen (2012+) General Topics | 34 | 02-27-2019 08:56 PM |
| New 2014s still have early issues? Prospective buyer | Lord09 | Issues | Warranty | Recalls / TSB | 25 | 06-14-2014 04:42 AM |
| Early problems - speaker rasp and long turnover | Hawaiian | Issues | Warranty | Recalls / TSB | 44 | 08-30-2013 04:39 PM |
| Initial Issues / Problems | JDMSushi | AUSTRALIA | 56 | 09-30-2012 10:21 PM |
