Old 02-27-2023, 07:30 PM   #1
Darknd666
Drives: 2017 86
TSSFab front subframe VS factory front subframe
So im here to clarify weights of something that alot is not mentioned about and say some very nice things about the TSSFab subframe for the ZN6 chassis.
To the point,
Factory subframe and supports: 24.4 lbs.
TSSFab subframe: 20 lbs. Shipped (only weight i have on it as i did not weigh or have access to a scale during install) this weight includes the supports.
Now for the good stuff, the quality was amazing! Install was easy, all the holes lined up perfectly.
The bad, kit came with bolts, however i had to go to lowes as there were some missing or the wrong bolts shipped for the steering rack. Was not complaining because the product was not affected by this. I regret not getting powder coat from TSSFab, i painted mine with high temp engine enamel 550° rated. Baked @250 for one hour. Meh is all i have to say 😂.
The drive home felt solid and more rigid, i couldnt tell what was different but something felt different on the drive home. The purpose was to gain clearance for my fat ass 3inch overpipe, alas this still did not solve my issue, again no fault on TSSFab as the product isnt really designed for that specifically as far as i know. I will be modifying the overpipe because it costs less than the frame plus i really like it and i have Megan racing mounts coming in the mail to assist in my rattling conundrum.
Darknd666 is offline   Reply With Quote
The Following 5 Users Say Thank You to Darknd666 For This Useful Post:
DarkPira7e (02-27-2023), Joveen (02-27-2023), ML (03-25-2024), venenon (04-10-2024), Wally86 (03-01-2023)
Old 02-27-2023, 07:32 PM   #2
Darknd666
Drives: 2017 86
Photos
Old 02-27-2023, 07:35 PM   #3
Darknd666
Drives: 2017 86
Overpipe still touches... unfortunately. Gonna have an exhaust shop notch it out or do something magical lol.
Old 02-27-2023, 11:15 PM   #4
norcalpb
norcalpb's Avatar
It’s cool but I wish it kept the threaded holes for the skid plate.
Old 02-28-2023, 07:56 AM   #5
Darknd666
Drives: 2017 86
The skid plate is not installed in that photo, the skid plate still goes back on as far as i know, i just havent got around to it as i need to have my overpipe modded. I left it off for now and ziptied and duct taped the plastic down, i would NEVER recommend to ride around with no skid plate in these cars. I have a bent control arm bolt because of a manhole cover....needless to say it still can be aligned properly.
The Following User Says Thank You to Darknd666 For This Useful Post:
norcalpb (02-28-2023)
Old 02-28-2023, 12:42 PM   #6
norcalpb
norcalpb's Avatar
On the stock crossmember there are 4x m8 holes for the back of the skid plate but maybe they just aren’t showing up on the pics of this new piece.
Old 02-28-2023, 01:56 PM   #7
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Potentially cool part for the inveterate tinkerer. The lack of plate mounts would be a show stopper.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 02-28-2023, 02:56 PM   #8
norcalpb
norcalpb's Avatar
Unfortunately the supports are also missing holes for the transmission cover. So 2x covers that potentially can’t go back on.
I just swapped to gr86 front bracing but if I didn’t I would consider doing this and welding threaded bungs on. On their website they say this piece is 15lbs.
Old 02-28-2023, 03:11 PM   #9
Capt Spaulding
Persona Non Grata
That’s unfortunate. Getting old gas (edit; HAS killed - my old age GAS is pretty deadly, too) really killed my motivation to do stuff like that.
Edit edit: what makes the GR bracing special?
Old 02-28-2023, 04:28 PM   #10
norcalpb
norcalpb's Avatar
The GR86/new brz have redesigned crossmember supports that allow for mounting a new boomerang shaped brace.
I always wanted a 2 piece crossmember brace after seeing STi and TRD offerings, but ended up settling with a 1 piece tanable brace. Big mistake, made the car too rough imo.
Then Toyota/Subaru comes out with this new design that now supersedes the STi draw stiffener, so I had to have it.
Old 02-28-2023, 04:32 PM   #11
norcalpb
norcalpb's Avatar
But those side supports on the tubular crossmember look like they provide the same effect (being super rigid) as the new boomerang braces.
Old 02-28-2023, 06:22 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I can't get over how happy you were that you had to take your pants off for the first photo
Overpipe clearance sounds like an overpipe issue. My 3" clears fine with the stock subframe.
Code Monkey (02-28-2023)
Old 02-28-2023, 09:18 PM   #13
Darknd666
Drives: 2017 86
I see now...damn i wish id noticed this before hand, couldve had them weld some on
Yeah there isnt enough to hold it on
Old 03-01-2023, 10:46 AM   #14
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Can you give an idea what was involved in swapping the 2nd gen bracing in? Any mounting holes need to be drilled / tapped? Do all the underbody covers fit, etc.?
I have a used 2018 tS crossmember and flexible draw stiffener that I haven't got installed yet, but had thought doing about this swap instead...
Tatsu333 is offline   Reply With Quote
FS: PBM Solid Subframe & Diff Risers, Pedders Camber Plates, Racer X Fab Front LCA's frs_adrian Brakes, Suspension, Chassis 3 11-07-2023 05:16 AM
Swapping out front subframe on jack stands? Tatsu333 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-16-2022 11:09 AM
HELP: Spoon Front Subframe Rigid Collar Install nichiolas DIY (Do-It-Yourself) Guides 1 12-25-2016 07:44 AM
FS: GTSPEC Front 4 Point Subframe Reinforment Tie Brace Atticus8631 Brakes, Suspension, Chassis 1 11-15-2015 12:27 PM
torque specs for front and rear subframe bolts mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-17-2015 02:54 PM
