Old 02-22-2023, 07:17 PM   #99
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Originally Posted by Tatsu333 View Post
OK, so ONE more question - on the fitment table, the 17x9" ET48 SM-10RS is listed as face profile C2. How does that compare to the other profiles (1, 2 and 3)? I'm guessing shallower than a 2 but not as shallow as a 1...?
Great guess! Essentially the C2 fitment is to designate that the top half of the spoke (connecting to the barrel) is slightly convex, while the lower half of the spoke (connecting to the hub) has similar concavity to a Profile 2 wheel.
Here's an example with our VS-5RS:
Profile 1
Profile C2
Profile 2
Profile 3
We'll be updating our site to reflect these profiles for SM-10RS as well.
Hope that helps!
APEX Race Parts is offline   Reply With Quote
Old 02-23-2023, 11:47 AM   #100
Tatsu333
Drives: 2020 BRZ Sport Tech RS
So would the top half of the spoke protrude more beyond the plane of the lip than a profile 1? It kind of looks that way from the pictures, but not sure without seeing them in full profile rather than 3/4 view.
Tatsu333 is offline   Reply With Quote
Old 02-23-2023, 02:30 PM   #101
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The spokes do protrude slightly beyond the lip on my VS-5RS
Old 02-23-2023, 05:26 PM   #102
APEX Race Parts
Yes, the C2 protrudes slightly up top with concavity near the center.
Old 02-23-2023, 07:23 PM   #103
APEX Race Parts
As noted in our February 17th update we added a variety of brand new fitments to the deal, some of which were engineered specifically for the 86/BRZ. To supplement those new wheel fitments we wanted to let the community know that 86/BRZ compatible TPMS sensors have also been added to our 18" Forged Sprint Group Buy.
We also want to take the opportunity to share some of the details and benefits of each of these new fitments:
(17x9.5” ET40 VS-5RS Shown)
18x9” ET42: This dual-duty street or track fitment is a great option for both Gen 1 and Gen 2 owners that are looking to increase performance. This configuration allows for increased brake clearance and the option to run significantly wider tires than stock without requiring heavy modifications. For a Gen 1 car, this is typically a direct fit option though we recommend mild camber with tires that run wide. For a Gen 2 car, this fitment typically requires mild negative camber for clearance and depending on tire choice may require slight trimming of the rear quarter.
18x9.5” ET40: An aggressive fitment for when you want as much brake clearance and tire width as possible, or if you want the most spoke concavity that we offer for these chassis. This is a popular Gen 1 fitment among track enthusiasts, and it’s often paired with 255 or 265mm tire to maximize grip. This fitment requires aftermarket coilovers with a slimmer silhouette than stock and a minimum of -2.5º camber to fit properly. For a Gen 2 car, in addition to the aftermarket coilovers and aggressive alignment settings, trimming of the rear quarter panel is necessary for clearance.
Be sure to check out our Vehicle Specific Fitment Guides to see all available combinations for your vehicle.
Old 03-01-2023, 04:31 PM   #104
APEX Race Parts
Timur's Toyota GR86 in Neptune Blue @rrrr.family
APEX Wheels Forged SM-10RS in Brushed Clear
F/R: 17x9" ET48 with 255/40-17 Nitto NT01
Mods:
Front 10mm Spacer
Annex CSP Coilovers
Brembo Front BM-4 Caliper
CSG Brake Pads
For transparency this is a render of the SM-10RS using an accurate face profile, tire size, ride height etc. As mentioned in our previous post we are very close to shooting real SM-10RS sample wheels for 86/BRZ, but we wanted to get some inspiration out there ASAP and this rendering is a great representation of what to expect.
Old 03-01-2023, 07:00 PM   #105
Pat
Pat's Avatar
Drives: 2023 BRZ
ALLLL bzns right there.
Old 03-02-2023, 04:32 PM   #106
jflogerzi
jflogerzi's Avatar
Damnnnnnniiiitttttttt..... I need to get some new wheels this year. Forged wheels here I come. My Arc-8's will become my low grip tire option.
2013 Series 10 FRS #553
Old 03-05-2023, 03:11 PM   #107
ihavefat
Drives: 2018 BRZ
Man both the SM-10RS and VS-5RS look killer. Do we know what the weight may be like on 17x8 SM-10RS and if it would clear the perf pck brembos ?
ihavefat is offline   Reply With Quote
Old 03-06-2023, 06:23 PM   #108
APEX Race Parts
We will be releasing weight figures for our full range of SM-10RS soon. That said, all of our 86/BRZ fitments are intended to clear Performance Pack Brembos. This includes our new 17x8" ET40 fitment.
Old 03-07-2023, 03:56 PM   #109
APEX Race Parts
Scion FR-S
APEX Wheels Forged SM-10RS in Satin Bronze
F/R: 17x10" ET42 with 255/40-17 Tires
As we're getting real sample wheels in for proper on-car photography, we wanted to throw out another teaser photo to share some of our progress with the community. Enjoy!
Old 03-07-2023, 05:20 PM   #110
gt5759
Drives: 2017 BRZ
When does the group buy start on the 17x10?
gt5759 is offline   Reply With Quote
Old 03-07-2023, 07:35 PM   #111
APEX Race Parts
We are aiming to launch our 17" Group Buy in the next few weeks!
Old 03-09-2023, 07:29 PM   #112
APEX Race Parts
Joe's Scion FR-S
F/R: 17x10" ET42 with 255/40-17 Maxxis RC-1
Mods:
Front 15mm Spacer
Annex Suspension Clubspec Pro Coilovers (12K/14K)
Cusco Front Lower Control Arms
FIGS Engineering Trac and Toe Arms
Perrin Front Sway Bar
ST Rear Sway Bar
Wilwood 6-Pot Front BBK / Wilwood 4-Pot Rear BBK
Alignment:
-4ºF / -2.3ºR
► APEX | Introducing The All-New Forged EC-7R 5x100 86/BRZ Wheel Line APEX Race Parts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 12-09-2022 03:14 PM
► APEX | Fully Forged Lightweight 86/BRZ Wheels APEX Race Parts Wheels and Tires 59 07-20-2022 12:20 PM
SOLD : Apex EC-7R Forged 17x9 Bronze Wheels MoarGeesPlease Wheels and Tires 5 10-04-2021 09:40 AM
► APEX | NorCal 86/BRZ Needed For Photoshoot With Our All-New Forged EC-7R Wheels APEX Race Parts Northern California 3 07-06-2020 04:05 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
