| Software Tuning Discuss all software tuning topics. |
Drives: 2019 Subaru BRZ
Tactrix logging config for ZA1JS10C (2017-2019)
Hi all, I've created a theoretically valid Tactrix logging config for ZA1JS10C (stock), and I'd like to see how it works for others.
This will work on S10C (2017-2019, afaik) with the gen1.5 intake. This will not work on K-series tuner ROMs that have been calid-hacked to S10C, nor on V00C00G (2020, afaik). It might work on other S-series manual-shift ROMs, but I don't really know yet. Anyways, I'm getting good logs from it for my uses so it's time to see whether anyone sees problems logging with it. Feedback welcome -- and my gratitude to those who came before me that developed the original logcfg.txt files; this wouldn't have been possible without your efforts. Romraider XML definitions for S10C: https://www.ft86club.com/forums/show....php?p=3572241 Last edited by callisto; 03-11-2023 at 09:32 PM. |
#2 |
Here's v02. I added the port injection ratio (%) target and ECT compensation amounts:
Code:
; final port injection ratio target after PI Ratio calculations paramname = DiPi_ratio_result paramid = 0xFFF8A394 isfloat = 1 ;; final output of lookups in tables "PI Ratio ECT Compensation"; ;; by default, no compensations are applied when ECT >= 80C paramname = DiPi_ECT_ratio paramid = 0xFFF8A518 isfloat = 1 OTS tunes derived (calid hacked) from K0xx should be able to use these addresses instead; the code is the same (but I haven't tested them): Code:
FFF8A448 DiPi_ratio_result FFF8A5C4 DiPi_ECT_ratio |
| The Following User Says Thank You to callisto For This Useful Post: | AussieBRZ (02-21-2023) |
| Tags |
| za1js10c |
| Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging | steve99 | Software Tuning | 1094 | 01-18-2026 05:44 AM |
| Partial maps for the 2017 S10C rom (ZA1JS10C) | callisto | Software Tuning | 5 | 12-24-2022 12:56 AM |
| 10/16 Tactrix Logging | Roadcone | Software Tuning | 4 | 11-01-2016 08:32 PM |
| Problem with Tactrix OpenPort Logging | Shady195 | Software Tuning | 6 | 05-28-2015 06:52 AM |
| Thunderhill 3/2/2013 Bypass Config | sw20kosh | Northern California | 12 | 03-08-2013 11:06 PM |
