Old 05-27-2015, 07:39 PM   #1
Shady195
Drives: '13 10 Series FRS #1203
Problem with Tactrix OpenPort Logging
I spoke to @steve99 about this as well but was wondering if anyone else had ideas.
I seem to be having an issue where im getting hundreds of tiny logs generated when I try to log with my openport. Steve pointed that its due to a bad connection, I took his advice and tried bending the pins inwords a bit but im still having an issue.
Reading/Flashing tunes does not seem to be an issue, ive never had a hiccup doing either which is why i never assumed a bad connection but its really annoying consolidating logs together. It's easy enough using the command prompt but it messes things up a bit and still requires a little work in excel to get everything proper.
Shady195 is offline   Reply With Quote
Old 05-27-2015, 08:27 PM   #2
phrosty
Posting your config file might help.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 05-27-2015, 08:32 PM   #3
Shady195
here is my config
Old 05-27-2015, 09:15 PM   #4
steve99
Originally Posted by Shady195 View Post
here is my config
Remove or comment out the "triggers" they seem to be a problem.
without triggers it will just log when you plug it in and stop when you turn car off or unplug.
ie these lines
;conditionrpn = RPM,0,> action = start
;conditionrpn = RPM,0,== action = stop
Old 05-27-2015, 09:35 PM   #5
Shady195
I'll give that a try. Thanks Steve!
Old 05-27-2015, 10:32 PM   #6
Shady195
And that fixed it. Just did about 15 mins of logging and a few pulls and all is good.
The Following 3 Users Say Thank You to Shady195 For This Useful Post:
aagun (05-28-2015), steve99 (05-28-2015), ztan (05-28-2015)
Old 05-28-2015, 05:52 AM   #7
ztan
Drives: Toyota 86
Tactrix can be tempermental.
Triggers can make the behaviour odd.
I have taken to having all the parameter addresses in ascending order - may not make a difference, but my OCD feels they work better that way.
Sometimes, the text encoding makes a difference also - I use UTF-8 without BOM.
ztan is offline   Reply With Quote
The Following User Says Thank You to ztan For This Useful Post:
tactrix openport 2.0 statik Engine, Exhaust, Bolt-Ons 2 12-24-2014 01:59 AM
WTB: TacTrix OpenPort 2.0 Shady195 Want-To-Buy Requests 1 09-07-2014 11:52 AM
Tactrix Openport 2.0 Tuning Device Akari Engine, Exhaust, Bolt-Ons 1 08-21-2014 05:04 PM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
