Old 02-16-2023, 07:28 PM   #29
Originally Posted by VoltsFRS2013 View Post
I've always ran 0W-20 and had no issues, however I think i'll be swapping over to 5W-20 on my next change.
The five (5) part in 5W-20 doesn't give you anything except higher pressure on cold start and lower fuel efficiency. 0w-30 is the correct choice. edit: ...in the sense of taking advantage of modern chemistry in lubricants. I read back and saw Tokay's post about using 0w-40. That is the more correct choice.
bradsm87 (02-16-2023), Tokay444 (02-17-2023)
Old 02-16-2023, 11:46 PM   #30
bradsm87
Drives: It has 4 wheels
Originally Posted by H380 View Post
Also any 0 weight oil is made from 100% man-made synthetic base stock oil. 5 weight and higher oil is made from crude oil base and modified enough to be called "Full Synthetic". That is why 0w-20 will cost more than 5w-30 from the same brand.
I used to be dead against 5w-30 for this reason, however when you look and the individual viscosity specs, many 5w-30 oils could just as easily be labelled as a 0w-30, but for some reason, 0w-30 never took off as a manufacturer spec BUT you look at a modern API SP Resource Conserving and ILSAC GF-6A compliant 5w-30 oil and it has a high viscosity index and it could just as easily be branded as a 0w-30. To meet these modern specs, they do actually need a nice high viscosity index and good base stocks. I think these modern oils should just be branded as 0w-30 because they are much thinner when cold than what most 5w-30 oils used to be.
bradsm87 is offline   Reply With Quote
Old 02-17-2023, 04:31 AM   #31
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by Tokay444 View Post
Which brings us back to the EPA. Thanks for playing.
Witch brings us again to the EPA only being a USA thing.
Why is this posed in a AUS manual then?
Why do the other NON USA vehicles that use the same engine also use 0W-20?
Old 02-17-2023, 09:24 AM   #32
Tokay444
To hit advertised fuel economy numbers, and so they can sell you a new car when the warranty is over, because you need one. It certainly isn't for engine longevity.
Old 02-17-2023, 10:37 AM   #33
Almost every country in the world has their equivalent to the EPA. Most of the requirements laid out by the EPA in the US are set by standard international agreements.
Old 02-17-2023, 05:08 PM   #34
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
I disagree, only because of these few snippets from the GR Forum. I'd just post a link to the thread but I don't think it allows me to do that on here. It will censor the link
Among other things that individual has posted with statistics and logic to back it up, 5w20 is my go to
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
The Following User Says Thank You to VoltsFRS2013 For This Useful Post:
Ultramaroon (02-17-2023)
Old 02-17-2023, 06:31 PM   #35
Seems legit. As for my own machine, I've run the mobile-1 0w-20 exclusively and adjust my oil cooler flow to maintain ~75 PSI max pressure. It coincidentally works out to ~180 degrees F, which is in line with the service manual.
I think engine longevity is more tied to build precision/quality than choice of lubricant. If the bearings are going to scuff hard, might as well get the rebuild over with sooner than later.
VoltsFRS2013 (02-17-2023)
Old 02-17-2023, 07:10 PM   #36
Jianlun
Drives: GR86 RC
Hiw do you adjust your oil cooler flow? Have a bypass with a manual valve? Always wondered if i should do that. Bypass 50% for normal days and close the value right up (no bypass) on track days.
Jianlun is offline   Reply With Quote
Old 02-17-2023, 07:20 PM   #37
VoltsFRS2013
I've agree! I'm only making the switch to 5w20 just because of some stuff I've read into and knowing my driving habits. In the end though, does it really make a difference? who knows lol
The oil debate will always go on and on. I think if you're really pushing the car or tracking the car, you should focus more on how can i mitigate the risk of the oil overheating vs what the minute differences between a 0w20, 5w20 and 5w30 etc are going to do for you.
That's just my opinion though
Old 02-17-2023, 08:58 PM   #38
Exactly! The diverter valve was a lucky find. I now realize it's a unicorn designed by @VerusEric in a past life.
Old 02-17-2023, 09:02 PM   #39
Haha.... ditto.
Old 02-18-2023, 04:52 AM   #40
bradsm87
Because the USA manuals make no mention of anything other than 0w-20 being acceptable other than top-ups. Japanese and Australian manuals not only say 5w-30 is fine but they even say thicker than 0w-20 should be used under harsh conditions. The USA has all the language about 5w-30 or 0w-30 stripped out. The engines are not different between countries.
Old 02-18-2023, 05:08 AM   #41
bradsm87
Interestingly, the Australian BRZ owner's manual says that you can just use any 0w-20, 5w-20, 0w-30 or 5w-30 ACEA A3 or A5 oil.
I'll still use an API SP Resource Conserving and ILSAC GF-6A oil anyway because there is a good option readily available to me but there are a huge amount of A3/A5 oils that are not compliant with the SN, SN Plus or SP Resource Conserving, GF-5 or GF-6A spec, that Subaru Australia deem fine for the BRZ.
Old 02-19-2023, 12:17 AM   #42
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Would you mind taking a few pictures and starting a new thread?
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
Ultramaroon (02-19-2023)
BRZ Owners Manual boxer_boy Want-To-Buy Requests 2 01-29-2015 10:11 AM
Useful additions to the BRZ owners manual mike_ekim1024 BRZ First-Gen (2012+) — General Topics 1 04-08-2013 09:24 PM
FR-S Owners Manual EBMCS03 Scion FR-S / Toyota 86 GT86 General Forum 7 11-18-2012 12:58 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 11:09 PM
Did everyone get their new owners manual yet? Dave-ROR BRZ First-Gen (2012+) — General Topics 15 06-03-2012 01:43 PM
