Old 03-15-2022, 06:35 PM   #15
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
Originally Posted by Grosbard View Post
@Daedex Would you mind posting a link to the magnetic drain plug you got, please? It would be much appreciated!
I gotchu fam:
https://www.amazon.com/dp/B086RS22TT...ing=UTF8&psc=1
I would stay way from greddy if possible. Had one in the previous gen, and the magnet fell out.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
The Following User Says Thank You to Daedex For This Useful Post:
Grosbard (03-16-2022)
Old 03-15-2022, 07:06 PM   #16
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Daedex View Post
Now, for transmission/diffy fluid, there's an overwhelming consensus (maybe not consensus, but you can't go wrong with it) for Motuls gear 300 75w-90. Its just really good. Definitely removes some of the clumsy shift feel, especially between 1st and 2nd gear.
I hated every morning when Motul Gear 300 was in my transmission.
Switched to Red Line MT-90 and it's way smoother when cold.
The Following User Says Thank You to timurrrr For This Useful Post:
Wally86 (03-16-2022)
Old 03-16-2022, 04:22 PM   #17
Grosbard
Drives: 2022 BRZ coming
I gotchu fam:
Thank you, @Daedex!
Grosbard is offline   Reply With Quote
Old 12-14-2022, 12:23 PM   #18
HysteriaDxM
Drives: GR86 / Elantra N
Coming from two FA20's, I always switched to 5w-30 full synthetic, but I also live in Phoenix where summers are 120 deg. I sent in an oil analysis and I remember metal particulates were cut in half after switching on my 2017 BRZ.
Im at 1,200 miles on this one, and I just switched to 5w-30 and a magnetic drain plug.
I also ordered some test kits, and I'll send in an oil analysis on my next oil change in the next 2k miles.
Sorry to revive an old thread, but @Daedex did you ever get that analysis back on the 5w-30?
HysteriaDxM is offline   Reply With Quote
The Following User Says Thank You to HysteriaDxM For This Useful Post:
Wally86 (12-21-2022)
Old 12-21-2022, 10:08 AM   #19
Ernest72
Interested to hear the results as well. Here in NY I will stick with a good 0w20 like Motul, as I do a lot of highway and only some spirited runs. But if I was tracking I would use 5w30 or higher.
The Following User Says Thank You to Ernest72 For This Useful Post:
Old 02-15-2023, 11:19 PM   #20
bradsm87
Drives: It has 4 wheels
Here is the Australian manual. Proof that 0w-20 is just EPA-enforced emissions compliance BS in the USA.
bradsm87 is offline   Reply With Quote
The Following User Says Thank You to bradsm87 For This Useful Post:
Tokay444 (02-16-2023)
Old 02-16-2023, 01:54 AM   #21
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Same as for gen1 cars.
Follow the build thread for my GR86!
Old 02-16-2023, 03:12 AM   #22
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Love your "proof".
Is it weird living on the bottom side of the flat earth?
Love that you took the time to highlight that the manual says "if the vehicle is operated at high speeds or under extreme load conditions."
You know RACE CARS.
Skipping over the paragraph that says 0W-20 is what comes from the factory and gives better MPG and cold starting if that's a factor.
0W-20 is preferred right there in black and white.
The Following User Says Thank You to x808drifter For This Useful Post:
OkieSnuffBox (02-20-2023)
Old 02-16-2023, 06:00 AM   #23
Teseo
Drives: frs
Originally Posted by x808drifter View Post
Love your "proof".
You know RACE CARS.
Skipping over the paragraph that says 0-W20 is what comes from the factory and gives better MPG and cold starting if that's a factor.
0-W20 is preferred right there in black and white.
Their "cold weathers" is 85⁰F
Old 02-16-2023, 07:11 AM   #24
H380
H380's Avatar
Drives: 2022 BRZ Limited WR Blue MT
Also any 0 weight oil is made from 100% man-made synthetic base stock oil. 5 weight and higher oil is made from crude oil base and modified enough to be called "Full Synthetic". That is why 0w-20 will cost more than 5w-30 from the same brand.
H380 is offline   Reply With Quote
Old 02-16-2023, 08:21 AM   #25
x808drifter
LMGTFY
I don't see 85 anywhere on what he posted. Where's that number coming from?
Even if we go by the useless temp graph they provided it also goes down below 0F. So what was your point exactly? Seriously asking.
The graph show 0W-20, 5W-20 and 5W-30 all exactly the same in temp. Below 0F to above 80F.
Old 02-16-2023, 09:08 AM   #26
Spektyr
Drives: GR86
It's probably coming from having talked with Australians.
I'm not going to say it's every single one - but the ones I know are epically cold-intolerant: confused as to how our entire infrastructure doesn't come grinding to a halt under 40F, and patently bewildered that I'll intentionally go outdoors to sit in a tree stand at 3F or colder.
Spektyr is offline   Reply With Quote
The Following 2 Users Say Thank You to Spektyr For This Useful Post:
Tcoat (02-16-2023), x808drifter (02-17-2023)
Old 02-16-2023, 11:19 AM   #27
Tokay444
Which brings us back to the EPA. Thanks for playing.
The Following User Says Thank You to Tokay444 For This Useful Post:
bradsm87 (02-16-2023)
Old 02-16-2023, 11:43 AM   #28
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
I've always ran 0W-20 and had no issues, however I think i'll be swapping over to 5W-20 on my next change.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
BRZ Owners Manual boxer_boy Want-To-Buy Requests 2 01-29-2015 09:11 AM
Useful additions to the BRZ owners manual mike_ekim1024 BRZ First-Gen (2012+) — General Topics 1 04-08-2013 08:24 PM
FR-S Owners Manual EBMCS03 Scion FR-S / Toyota 86 GT86 General Forum 7 11-18-2012 11:58 AM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 10:09 PM
Did everyone get their new owners manual yet? Dave-ROR BRZ First-Gen (2012+) — General Topics 15 06-03-2012 12:43 PM
