Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 03-09-2022, 03:30 PM   #1
ozafar
Drives: 2015 Scion FRS Release Series 1.0
Owners Manual Oil Anomaly
Hi all. So I think I found what could be a mistake. Some background info on this:
So I was calling Toyota to ensure that getting my next summer oil change in 5W-30 will not void the warranty. I used the text on page 381 in the Subaru owners manual (Thanks to *Axel from his thread: https://www.ft86club.com/forums/show...=owners+manual)
It states higher viscosity is required at high temps, so it says you can use 5W-30 oil.
Here is the anomaly: The Toyota rep told me that she doesn't see that, in fact, she sees "5W-20" in the Toyota owners manual, on the same page.
That makes no sense.
1. Both owners manuals should be the same regarding the engine....they are the same engine!!
2. Even if there's something different, the whole point of changing the oil (as the owners manual is literally stating) is for higher temps... It's the second number that describes oil behavior at higher temps.
Right? 5W-20 and 0W-20 will have the same behavior at higher temps.
So, do you think it's a mistake on Toyota's part? Shouldn't it say 5W-30 like Subaru states, and not 5W-20?
ozafar is offline   Reply With Quote
Old 03-09-2022, 03:59 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's not an anomaly - it's a different manufacturer having a different opinion on what is acceptable. Subaru may not see the need to confuse customers and potentially have them worry that they are not choosing the correct application for their needs, causing more support work for them.
It could also be that the oils used differ enough that Toyota's recommendation changes
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-09-2022, 10:15 PM   #3
gcmak
gcmak's Avatar
Drives: GR86
The Subaru manual states 5w-30 conventional oil. Not synthetic oil as stated for 0w-20. Would not expect 5w30 conventional to out perform the 0w20 synthetic.
gcmak is offline   Reply With Quote
The Following User Says Thank You to gcmak For This Useful Post:
Dake (03-11-2022)
Old 03-10-2022, 12:33 AM   #4
DrinkenBRZ
Drives: 10 RX-8 Spt, 20 BRZ Ltd, 21 Rubicon
Oil base stock will not impact performance at normal temperatures. Only the life cycle/resistance to blow by and heat degradation over time. 5w30 will have higher film strength, hence the grade.
DrinkenBRZ is offline   Reply With Quote
Old 03-10-2022, 01:58 AM   #5
Brz-123
My UK Subaru manual mentions a 5W-30 but does not mention a conventional oil. So manuals are written differently based on regions and oil availability.
20 weight oil is resource conserving aka fuel efficient and hence helps produce less emissions. So manufacturers now use it even in hot desert climates of the middle East. I don't see why one needs to move to 5W-30 at all. Use a quality synthetic 0W-20 and do not overthink it mate.Name:  20180806_191651.jpg
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
The Following 3 Users Say Thank You to Brz-123 For This Useful Post:
gcmak (03-10-2022), Opie (12-14-2022), Tcoat (03-10-2022)
Old 03-10-2022, 07:20 AM   #6
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Someone on the phone is tier 1 support. They could easily have misspoken.
You can read for yourself in the manual what is required (ILSAC GF-5 0w20). Keep your receipts. Do your oil analysis. Enjoy the peace of mind. Stop worrying and drive the thing.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
gcmak (03-10-2022)
Old 03-10-2022, 12:14 PM   #7
Tokay444
Don’t let the EPA tell you how to protect your engine.
0W40 from day 1. Drive. Year round in Canada. Hard track about. 200,000kms with no engine issues.
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
dsc_pat (03-10-2022), Jdmjunkie (03-10-2022), MrSkubi (12-16-2022), PLF69 (03-10-2022), Rustyoid (03-10-2022)
Old 03-10-2022, 12:21 PM   #8
dsc_pat
Drives: Too fast
You are a rare specie. I like you.
dsc_pat is offline   Reply With Quote
The Following 2 Users Say Thank You to dsc_pat For This Useful Post:
Jdmjunkie (03-10-2022), Tokay444 (03-10-2022)
Old 03-15-2022, 12:16 PM   #9
zze86
Drives: AE86, AP1
Look at the bearing oil clearances to get an idea of what oil viscosity to use. According to the service manual for Gen1, the FA20 oil clearances (no online access to Gen2 SM that I could find) should be between 0.00098" to 0.00217" which is a huge range honestly. Most bearing manufacturers have a suggested bearing clearance to oil chart. Here's one, the first result from Google.
According to the bearing clearances and this particular viscosity chart, a 5w20 is the recommended weight to use for most of the range of the bearing clearances, however 5w30 does fall within the looser end of the bearing clearances.
Not all oils are created equal though, particularly synthetics (which aren't even completely synthetic most of the time) and investigation into the particular oil's viscosity characteristics is probably suggested if you want to do a deep-dive.
Although once you deep-dive you see that there can be quite a large variance between the oil manufacturers and what is classified as what and then you begin to wonder what was the "standard" 5w20/5w30 oil that Toyota and Subaru referred to when they wrote their recommendation and what is the viscosity characteristics of that oil. Then you look at the charts and go also hmmm...
zze86 is offline   Reply With Quote
The Following User Says Thank You to zze86 For This Useful Post:
soundman98 (03-15-2022)
Old 03-15-2022, 02:09 PM   #10
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
Coming from two FA20's, I always switched to 5w-30 full synthetic, but I also live in Phoenix where summers are 120 deg. I sent in an oil analysis and I remember metal particulates were cut in half after switching on my 2017 BRZ.
Im at 1,200 miles on this one, and I just switched to 5w-30 and a magnetic drain plug.
I also ordered some test kits, and I'll send in an oil analysis on my next oil change in the next 2k miles.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
The Following User Says Thank You to Daedex For This Useful Post:
gcmak (03-15-2022)
Old 03-15-2022, 02:16 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
"0.025 — 0.055 mm (0.0010 — 0.0022 inches)" for connecting rods of a FA24, basically the same.
timurrrr is offline   Reply With Quote
Old 03-15-2022, 03:27 PM   #12
Slowv6
Drives: Gr86
May i just have a oil change for dummy list of fluid i need ? i know it's a giant rabbit hole but is there a general consensus??
Besides oil weight , Brand and which type?
How about transmission and differential?
Slowv6 is offline   Reply With Quote
Old 03-15-2022, 05:23 PM   #13
Daedex
That One Guy
Daedex's Avatar
Not sure of general consensus for engine oil. Any big brand for full synthetic 5w-30 or 0w-20 will work honestly. Personally, I really like Motul as a company, but they are pricey in the states.
Now, for transmission/diffy fluid, there's an overwhelming consensus (maybe not consensus, but you can't go wrong with it) for Motuls gear 300 75w-90. Its just really good. Definitely removes some of the clumsy shift feel, especially between 1st and 2nd gear.
Old 03-15-2022, 05:44 PM   #14
Grosbard
Drives: 2022 BRZ coming
@Daedex Would you mind posting a link to the magnetic drain plug you got, please? It would be much appreciated!
Grosbard is offline   Reply With Quote
BRZ Owners Manual boxer_boy Want-To-Buy Requests 2 01-29-2015 09:11 AM
Useful additions to the BRZ owners manual mike_ekim1024 BRZ First-Gen (2012+) — General Topics 1 04-08-2013 08:24 PM
FR-S Owners Manual EBMCS03 Scion FR-S / Toyota 86 GT86 General Forum 7 11-18-2012 11:58 AM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 10:09 PM
Did everyone get their new owners manual yet? Dave-ROR BRZ First-Gen (2012+) — General Topics 15 06-03-2012 12:43 PM
