Old 02-07-2023, 10:54 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
rev in neutral but with clutch disengaged (pedal pressed down)
if noise disappears then your problem is with transmission input shaft.
if noise remains (or is worse) then your issue is with the pressure plate, throwout bearing, or something from fork forward to flywheel.
Capt Spaulding (02-07-2023)
Old 02-08-2023, 02:07 AM   #16
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Yes im starting to think thats the problem....how can I spend $2000 and the throw out bearing go in three weeks.
Video of wobbly clutch fork:
https://youtube.com/shorts/3I7vuiwqLD0?feature=share
FRS2017 is offline   Reply With Quote
Old 02-08-2023, 11:57 AM   #17
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Originally Posted by FRS2017 View Post
It goes away when clutch id pressed in.
Then it is not the throw out bearing, and is likely the transmission or input shaft bearing.
My guess is some installation error.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
Last edited by terboboost; 02-08-2023 at 06:27 PM. Reason: It is "likely" transmission, not "unlikely"
terboboost is offline   Reply With Quote
The Following User Says Thank You to terboboost For This Useful Post:
x808drifter (02-09-2023)
Old 02-08-2023, 04:00 PM   #18
mav1178
mav1178's Avatar
Yes noise gets worse when driving.
Going to have to get it checked as it sounds serious.
completely missed this post earlier in the thread.
if it goes away when pedal is depressed, then your transmission input shaft bearing is going bad.
source: I just spent $600 last year to rebuild my stock S13 240SX transmission because I had the exact same issue with an OE replacement clutch.
Old 02-08-2023, 06:26 PM   #19
terboboost
terboboost's Avatar
Correct, my bad, got confused there for a second. Probably transmission input shaft or something else in the trans.
Old 02-08-2023, 09:48 PM   #20
Grady
Grady's Avatar
If everything was good prior to clutch then the input shaft probably did not degrade that fast. Generally speaking “it was working until we did X” then X is the problem.
Old 02-08-2023, 10:46 PM   #21
FRS2017
Enthusiast 86
FRS2017's Avatar
Thanks for help guys you been more than helpfull figguring this one out.
My 2015 Toyota 86 is going in for an inspection on Monday, by the same people who installed the clutch. Everyone is saying to send it back to the people who installed the clutch as they can warranty their work.
I will keep you posted. Funny enough when the problem happened I was driving back from holiday a 3 hour 200 km trip there and back. I was thinking my car is so reliable and i have not had any problems. It's the first time driving at 110 km on this trip.
The Following User Says Thank You to FRS2017 For This Useful Post:
Old 02-14-2023, 06:41 AM   #22
FRS2017
Enthusiast 86
FRS2017's Avatar
Got my car back and they replaced a $53 thrust bearing. The noise has gone, so now see if I can get my money back through a warranty claim for the $567 I paid to get the transmission out and inspected.
What a pain the HASS.
The Following 2 Users Say Thank You to FRS2017 For This Useful Post:
Wally86 (02-14-2023), x808drifter (02-14-2023)
Old 02-14-2023, 05:12 PM   #23
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Which thrust bearing did they replace?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-14-2023, 05:37 PM   #24
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Should be the throwout bearing. The flywheel has the pilot bearing(bushing).
Old 02-14-2023, 09:01 PM   #25
Capt Spaulding
Persona Non Grata
That’s my take. I don’t know that I’d call the throw out bearing a thrust bearing. Technically I guess you could, but I don’t remember ever having heard it called that.
Old 02-15-2023, 09:47 AM   #26
Grady
Grady's Avatar
Read their warranty T&C’s. It spells out how much per hour you could be reimbursed. And of course everything you need to do.
Any Pictures of the issue?
Old 03-01-2023, 11:02 AM   #27
FRS2017
Enthusiast 86
FRS2017's Avatar
So, ive finally got a response from Australian Clutch Services. I need to file a warranty claim and go with the original seller of the clutch, which ive done and now waiting on a response from them to get back to me.
Dont really have high hopes as it would be easier just to ignore.
Capt Spaulding (03-02-2023), soundman98 (03-02-2023)
Old 04-11-2023, 07:16 AM   #28
FRS2017
Enthusiast 86
FRS2017's Avatar
Still waiting for a response from Australian Clutch Services.
This just shocking how long ive waited.
Clicking noise while Driving stops when Clutch is pressed Inteze Engine, Exhaust, Transmission 12 04-09-2020 02:07 PM
Mushy clutch pedal and strange noise after 4k RPM's hxt_BRZ Issues | Warranty | Recalls / TSB 12 09-30-2019 10:18 PM
Twin Disc Clutch Discussion GsxrMe Engine, Exhaust, Transmission 3 03-17-2017 06:32 PM
Anyone regret twin disc clutch? Kiske Engine, Exhaust, Transmission 23 11-09-2016 03:23 PM
SOLD!!! EXEDY TWIN DISC Clutch Kit Sportsguy83 Transmission and Driveline 27 10-04-2014 10:06 AM
