#855 | |
Drives: 86 GT
#856 |
Drives: 2013 Toyota 86
#857 |
Hi Guys,
Managed to find a OBD reader that works perfectly . I have had trouble using the ( Orange ) OBD Reader , which has the latest firmware . It would reset oil temps or not read at all even the fuel PID did not work . I have a different reader VGate , its works perfectly with both the OIL and Fuel PIDS . This reader uses the older firmware 1.5 . I hope this helps if anyone is having issues as to which OBD reader to use/try . They both cost the same and are both bluetooth . |
#858 | |
I have this disabled as well currently . Not sure if that made a difference as i tried it on other readers and they still had issues . The Vgate works just fine with it disabled . Last edited by 86GP; 01-15-2021 at 01:35 PM. |
#859 | |
6/22/12-2/6/24
#860 |
Drives: Toyota GT86
This seems to work on my GT86. (I use it directly via CAN bus, not Torque, but it should work the same.)
Fuel remaining in tank OBD2 Mode and PID: 0x2129 Minimum Value: 0 Maximum Value: Should not exceed 100 (0x64) -> 50 liters Scale factor: x1 Unit type: liter Equation: A/2 OBD Header: 0x7C0
#861 |
6/22/12-2/6/24
Is there any way to get the Oil Pressure readout from the ECU with a PID?
https://www.ft86club.com/forums/show...2&postcount=14 Edit: nevermind, seems like its just an on/off switch :/
#862 |
Drives: Toyota 86
If anybody is looking for the automatic transmission temperature PID, this one worked on my '17 86.
OBD2 Mode and PID: 0105 Minimum Value: 0 Maximum Value: 200 Scale factor: x1 Unit type: C Equation: A-40 OBD Header: TCM |
#863 | |
Wheels for Brains
PID: 2141 Min: 0 Max: 100 Scale Factor: x1 Type: % Eqn: MIN(100 : (1.1 * MAX((A-10))) Header: 7B0 Last edited by EndlessAzure; 05-11-2022 at 04:53 AM. |
#864 | |
Wheels for Brains
It comes down to what the interpretation of the PID is actually outputting. I think the consensus is that the PID value is % fuel level, but it really doesn't matter in the end because coincidentally when you divide by 2, it will also give the actual fuel tank capacity in liters. |
#865 | |
Drives: 2017 Toyota 86
This did not work for me. 2017 86 auto. It shows a temperature, but I don't think it is correct. What temps do you show? |
#866 |
waiting on yellow gas
Drives: 2017 BRZ Series.Yellow #247
Hey. I have the Elm 327 and Torque pro. Everything works great except for fuel pressure. I've tried to use all 3 options for fuel pressure and i get no data. I see that other people are able to monitor the HPFR without having to do anything. I've tried deleting and reinstalling torque pro but it hasn't helped. Is there any direction I can get towards what to try next or maybe the PID
#867 | |
Drives: 86 GT
DIY stuff at Compelica Works
#868 |
Human
Drives: 2015 BRZ Black
Does anyone know the vehicle speed pid and equation for a custom speed gauge? I want to add 10% to the speed to account for larger diamater tires.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
